Ac system giving trouble
#31
#32
Okay yes I'm using a mobile AC guy so he did come out the other day and it quit at about half of a small can of 134 so I will absolutely follow your instructions the next time he comes out. If there's any remnants of water still in the system will the vacuum pull that out?
#33
Yes sir the condesirr is new the compressor is new and accumulator is new... I have a new evaporator but Lord I don't want to have to try to put that in the other one blew out clean really really well I purchased it with water and it blew through very good clean. As did all the lines hoses and condenser which is all laying in the sun to really bake any leftover moisture out of them and the evaporator I'm blowing out every 10 minutes or so. I think you to know in on this and I will get it together tomorrow and have my mobile AC tech come by and finish the job in the order you said
#34
how long do i leave the jump in... Till about a half a can is that what you was talking about and then stop and take the jump out if it's taking it and continue on
#35
#37
Yeah I ordered them from everything from RockAuto and they just sent me the wrong thing I suppose I think what I'll do is just flip the factory ones over and go with that I mean the whole system was holding really well at full pressure the other day so I think I'm going to be all right with that. Again my friend I appreciate it to no end and I really think this is going to do it this time because I found a dime in the yard with heads up 😁.. of course not to mention all the professional advice I get! I want to keep my eye on things and help where I can for others. Tomorrow will tell the tale
#38
#39
Yessir, I did disassemble the entire system, tubes, hoses, (the new compressor had the shipping block bolted on it)
etc. This was before I installed a new accumulator as well of course it did not see it water. Just the tubes and hoses and evaporator and the condenser which I blew out very well and let them set in the Texas Sun for about 6 hours and blew them out several more times. The evaporator I did not remove but I blew and it out with air multiple times until not even any droplets came out. Reassemble the system and my mobile AC tech is apparently having something done to his back so I'm going to have to wait till next week because he's already been paid to do this. I believe from what I have learned it's going to be okay this time. I'm unaware of their problem originally but I'm assuming it must have been in the accumulator seeing there was no blockage anywhere that I could find. We should know more in a day or two.
#40
