Transfer shift rod bushings
Old 11-08-2021, 03:14 PM
Detour's Avatar
Detour
Detour is offline
Default Transfer shift rod bushings
I have order these bushing from two different places and both where the wrong size. Has anybody replaced there’s with any luck and still have the part number. 2001 2500 transfer case number 241DHD
Old 11-08-2021, 03:36 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
I used a washer and zip tie, no issues for past 6 months and I’ve gone in and out of 4x4 quite a few times
Old 11-08-2021, 04:53 PM
Detour's Avatar
Detour
Detour is offline
You don’t have any sloppy play because of the hole size with no bushing.
Old 11-08-2021, 06:54 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
I think we have parts manuals available for download in the FAQ/DIY section, should be able to find the part number there.
Old 11-08-2021, 08:38 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
I have maybe half inch of play back and forth, and the washer I used fit inside the groove and with the heavy duty zip tie it’s tight
Old 11-08-2021, 08:52 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Lightbulb
The grommet part number used on the 241DHD transfer case shifter on my '96 Ram 2500 4x4 is 3467791. I suspect the same bushing is used on the 2001 as well. Just FYI, they are a very tight fit when putting the rod into the bushing.
Old 11-09-2021, 06:41 AM
Detour's Avatar
Detour
Detour is offline
That part number is discontinued. I saw the trend on how to make a new setup from parts from Lowe’s. That’s probably what I’ll do.
Old 11-09-2021, 08:27 PM
AtomicDog's Avatar
AtomicDog
As of today, you can still find them by Googling the part number. There is an active eBay auction for a pair. You can also find them in Dorman assortment part number14041..
Old 11-10-2021, 04:13 PM
Detour's Avatar
Detour
Detour is offline
FYI Part number 3467791 is to small and I tried the assortment and only one that was hard plastic was bigger and destroyed it trying to put it in which was to big. I then call Dorman and they had no match to my vin # even the Crown Company.
Thanks everyone
Old 11-10-2021, 06:38 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Thanks everyone
Then your have the wrong linkage. All the bushing are the same for every second gen
Quick Reply: Transfer shift rod bushings
