95 magnum carb swap do i need a new brake booster?
Old May 6, 2022 | 11:10 AM
ThatRedRam's Avatar
ThatRedRam
Default 95 magnum carb swap do i need a new brake booster?
Im swapping the 360 magnum to a carb i have talked about this in other post. But my old boss which has a carbed truck and is a diesel mechanic told me that i may need a better brake booster or a vacume booster for it because i wont have as much vacuum with a carbed motor. I dont know if this is true but if it is what do i need to do i dont know much about the brake booster or vacume lines to it. What will i need if i even need to do it?
Old May 6, 2022 | 11:24 AM
The stock booster will work just fine. You will have the same vacuum with a carb, that you did with fuel injection. Unless you change the cam..... and then it depends on which cam you get.
Old May 6, 2022 | 11:25 AM
ThatRedRam's Avatar
ThatRedRam
oh yeah thats what he was talking about
the cam i am getting ****s with it
Old May 6, 2022 | 11:26 AM
ThatRedRam's Avatar
ThatRedRam
https://www.compcams.com/xtreme-ener...r-273-360.html
Old May 6, 2022 | 11:28 AM
ThatRedRam's Avatar
ThatRedRam
If you dont mind could you look over the specs and see if ill need to do anything about the vacuum. Im a nooby to this kind of stuff
ThatRedRam's Avatar
ThatRedRam
Also getting the monster eq heads you suggested
Old May 6, 2022 | 11:32 AM
AtomicDog's Avatar
AtomicDog
There are ways to compensate for a performance camshaft robbing the engine of vacuum. You can read more about it here - https://dsportmag.com/the-tech/educa...cuum-canister/
Old May 6, 2022 | 11:37 AM
ThatRedRam's Avatar
ThatRedRam
there vacuum pump would work but 450$$$$$$ idkkkkk about that
Old May 6, 2022 | 11:48 AM
That's a retrofit cam, and looks like it wants the shaft-style rockers. Not sure how well that will work in a magnum block. Oil for the top end changed dramatically from the LA to the magnum block.
Old May 6, 2022 | 11:49 AM
ThatRedRam's Avatar
ThatRedRam
Yeah cause honestly im struggling to pick out parts. Ive always had my dad help but i moved out and on my own now so im kinda still learning
