Quote:
I have replace that oneOriginally Posted by Cmcs24fan
I know they don't have a cam sensor but when mine thru the code it was the pickup under the cap and rotor.
Quote:
I didn't find excessive oil in the intake manifold. Also did a vacuum test from youtube without a gauge and it seems fine.Originally Posted by Moparite
Was the plenum gasket issue addressed?
Did you solve this issue? I have a 98 5.9l magnum that's literally doing the same thing to me. I've replaced the spark plugs, spark plug wires, cap & rotor, OEM crank sensor and pickup coil, the EVAP canister and charcoal canister, both O2 sensors, checked for plenum leak.... Nothing on all counts. I even replaced the safety neutral switch to address the issue with my reverse lights staying on with my night time taillights, which still didn't fix a thing!
Quote:
That's not true at all because I just replaced both pickup coil and put in a "Genuine Mopar crankshaft sensor" just 20mins ago and it still is doing this sputtering and backfiring crap around the same RPMs... Originally Posted by HeyYou
Intermittent cam/crank sensor signal. If you don't have a genuine mopar crank sensor in there, probably a good idea to get one.
So what else could it be? Because, I literally replaced everything single thing the original poster replaced as well, and it's pissing me off big time! Granted that my 98 1500 RWD has a 5.9 but there practically the same.
close
- Join DateApr 2010
- LocationClayton MI
Liked:4,223 Times in 3,915 Posts
Still have the Bosch O2 sensors in there?Originally Posted by Darren Davis
That's not true at all because I just replaced both pickup coil and put in a "Genuine Mopar crankshaft sensor" just 20mins ago and it still is doing this sputtering and backfiring crap around the same RPMs...So what else could it be? Because, I literally replaced everything single thing the original poster replaced as well, and it's pissing me off big time! Granted that my 98 1500 RWD has a 5.9 but there practically the same.
