Snow plow question
Old Nov 6, 2022 | 01:46 PM
jeryst's Avatar
jeryst
Default Snow plow question
I have a 2nd gen Ram 1500 and am looking for a plow.
My question is, will plows from later generations work, or are the mounts different?
Old Nov 6, 2022 | 04:38 PM
Mounts will be different.
Not sure if putting a plow on a half ton truck is a good idea though... I know, Lots of folks do it.... but, that still doesn't make it a good idea.
Old Nov 6, 2022 | 05:26 PM
AtomicDog's Avatar
AtomicDog
My truck had a plow option. I removed the plow hitch frame from under the truck and sold it, since I no longer had any plans to use it when I purchased the truck. I believe the plow was made by Myers.
Old Nov 6, 2022 | 09:12 PM
jeryst's Avatar
jeryst
I just have a small parking area but it's alongside a road and I'm tired of getting plowed in. Can never get anyone to plow me out either because they're all looking for the big jobs.
Old Nov 6, 2022 | 09:20 PM
jeryst's Avatar
jeryst
Old Nov 7, 2022 | 04:01 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
https://www.meyerproducts.com/config...-configuration Many to chose from for a 2001 light duty plows. I checked also for a 1995 it's the same
Old Nov 7, 2022 | 07:32 PM
jeryst's Avatar
jeryst
Thanks for the info. There are a lot of lightweight plows locally, but they all seem to be 3rd, 4th, and 5th gen, so I'm trying to find out if those mounts are very different from the 2nd gen mounts, or if maybe one of them will work on mine
Old Nov 7, 2022 | 07:52 PM
Keith_L's Avatar
Keith_L
3rd gen+ frames are significantly different so I wouldn't expect it to work without considerable fabrication.
Old Nov 7, 2022 | 07:54 PM
AtomicDog's Avatar
AtomicDog
Snow plow mounts will be different. The factory plow was made by Meyers. The mount setups are even different between plow manufacturers. You should be able to find a used plow/mount setup by checking Facebook Marketplace and Craigslist periodically, especially in areas that get lots of snow.
