Rebuilt ABS Controller
Half ton truck? If so, consider upgrading the front calipers to the light duty 3/4 ton fellers, They have a larger piston, so, more braking for the same pedal effort. They are a direct bolt-in swap.
If you are going to replace them anyway, might just as well replace them with something better, right?
When removing/installing bleeder screws, it's best to have some good flare nut wrenches handy to keep the bleeder screws from rounding. Here's an example, if you don't already have them - https://www.homedepot.com/p/Husky-SA...W6PC/203541511
Also, using some heat (Mapp gas or propane torch) on them might help to free them up.
Don't know if they will show them for 97 or newer..... maybe, but, they used the same calipers right up until 2000. I think. Whenever they went to the dual piston calipers... if you already have the dual piston, then, that's as good as it gets.
Try tapping on the bleeder valves with a hammer. Don't deform them too badly, but, it helps the lubricant penetrate deeper into the threads, and might allow you to crack 'em loose.
I have a set of those wrenches. I soaked the crap out of them. I don't have a torch handy at this time. Did try to tap them but just gave up. I don't remember the last time either of the fronts was replaced? It's not really the costly to just replace both and move forward. I figure with all this work. I will completely flush all the lines with new fluid. The way the tool I bought works is by taking new fluid from the bottle that will push any air trapped back up through the brake reservoir. I use it to drain what in there to make room for the fluid coming from the bottle. So by the time I finish bleeding all brakes. There shouldn't be any old fluid.
First thing. Happy Thanksgiving Gents. Ok, now back to subject. I changed out module. Both front calipers are new now. Did fronts first just to check how the new tool worked and made sure some fluid was in there as well heard them bleed out air through master cylinder. Went to back and just didn't seem right so I did both anyway. Anyway long story short. I just had the neighbor boy help me do the old fashion rear to front bleed and it seems to be working so far. Lights did go out after allowing it to run a little. No more dash light and brakes seem a lot better. I did find one proportional valve did bleed so fluid and now I do have fluid to the rear. Going to do some testing in the morning while getting some gas and returning old calipers. Will update again. Thanks for the help guys.
i figure i would point this out but you should anti seize the crap out of the new bleeder screws on the new calipers. any time i replace wheel cylinders or calipers it is something i do and it usually pays off in the future if i ever need to bleed them again.
I do this as well, though, I tend to wrap them in teflon tape, it not only prevents them from rusting together, it also seals the valve threads, so the fluid comes out where it is supposed to, not around the threads.
This is what's all been replaced. Module, Everything in the rear ( New drums coming), New Calipers front with new pads. All the brakes were due so this wasn't a throw everything at it other then the module but codes I had showed it needed to be replaced. I don't remember them off hand. If one or both valves are failing. That's going to be a issue to find since I believe they don't sell them anymore. That would have either be a salvage yard find or donor truck with no promises.
I was thinking the same thing but wasn't sure. The reverse bleeding works great on the front calipers but the rears are smaller and it just doesn't seem to work. If weather permits. I will be putting on the new drums tomorrow. That will pick up less travel for the rear brakes. My Chilton manual is very vague on bleeding ABS valves. I know the one with the access/rubber cap.I did push it down and bleed some air from it till nothing but fluid was coming out. After posting what was going on. I ran it up to NAPA to get my parts ( About maybe 15 blocks ) and back and lights didn't come on but brakes still didn't feel right but that could be the rears drums are worn out so once changed. I will be looking for some improvements. I don't remember if the mechanic adjusted the brakes either since there was no fluid going back at that time. I will update once everything is changed and bleed. Hopefully this will cure this.... Thanks
