Electric Fan help
Old Feb 15, 2023 | 01:25 PM
  #41
[QUOTE=BrendonM;3560811]
Stats are about as accurate as temp gauges. The rating is just a close approximation, and some are much better at it than others. The problem you run into with that particular code is, the PCM will do it's best to get the engine up to temp, which means fuel mileage suffers..... Unless you can tune it to the new value.[/QUOTE
can you set temp with an SCT handheld?
Nope. Need software that allows you to read, edit, and write from/to the PCM. HP tuners software will do it, but, that's like 600 bucks for a ONE vehicle license.
Old Feb 15, 2023 | 01:26 PM
  #42
BrendonM's Avatar
BrendonM
[QUOTE=HeyYou;3560812]
So back to the same issue. Boutta swap back to 195. Too many complications with that right now. Def not paying 600$ for a tuning software at the moment lol
Old Feb 15, 2023 | 04:26 PM
  #43
[QUOTE=BrendonM;3560813]
That is certainly the least expensive route. Might be the best as well.... The PCM expects that 195 stat, and that's what it's tuned for.
Old Feb 16, 2023 | 06:47 AM
  #44
Moparite's Avatar
Moparite
You can add a resistor to the wire on the temp sensor to fool the pcm to think it's running a 195.
Old Feb 16, 2023 | 07:59 AM
  #45
BrendonM's Avatar
BrendonM
Omg I just remembered, if I remove my stock shroud where do I put my reservoirs ? LOL. I totally forgot about that. I’m doing the Dual Fan one and I wanted to do it this weekend but I think I might have to wait now. I don’t have a shroud or know how or where to mount the tanks
Old Feb 19, 2023 | 10:37 PM
  #46
BrendonM's Avatar
BrendonM
Guys, it’s beginning to fail on me lol. As I said, the top was already terribly broken, it just finally gave out. I drove 2 hours to hangout with a friend I haven’t seen in a while. Found this when I got there, wasn’t there before. I got home okay today. It’s not fixed. Going to buy the 3 row and shroud on eBay this Tuesday.
Old Feb 20, 2023 | 06:45 PM
  #47
Moparite's Avatar
Moparite
Keep in mind the oem radiator has a 1 inch thick "row" so you need at least 3 X .333 to equal the stock radiator. Have seen them advertised as "3 row" and each tube is about a 1/4 inch witch is less cooling that stock. Also be sure to count the rows, Aftermarket radiators rarely ever have the same amount as stock usually less(same with heater cores).
Old Feb 22, 2023 | 12:34 AM
  #48
BrendonM's Avatar
BrendonM
Hello! It’s 0.57in per row. A total or 1.71in or so the seller says
Old Feb 22, 2023 | 06:42 AM
  #49
Moparite's Avatar
Moparite
Do you have a link? I know someone makes one similar to that but it's $300
Old Feb 22, 2023 | 12:42 PM
  #50
BrendonM's Avatar
BrendonM
Originally Posted by Ugly1
Sorry if that was confusing.
I was mostly just posting that shroud as an example for user dodgetruck2 to illustrate my theory about what I think may be an upgrade to the type of system he might be using. That probably wouldn't be my pick for you until possibly later down the road as a possible upgrade.
I and I think most people on the forum use shrouds by companies such as TCP Performance which hold dual 16" fans. Not sure if TCP sells just the shroud these days as they seem to want to sell the whole kit on their website. Though I think there are probably plenty of options on ebay.
Back in my day they didn't have anything cool like this or I probably would have this instead of what I have now....This might not be a bad thing for someone like you.....https://www.ebay.com/itm/18557221230...Bk9SR5jEnvTIYQ
^^ this link
