Shake/vibration in seat 45 mph
Old Mar 23, 2023 | 11:41 AM
Braintanned's Avatar
Braintanned
No shaking without shaft...I believe I am going to have the driveshaft balanced and probably replace tailshaft bushing and seal while it's out.
Old Mar 23, 2023 | 11:49 AM
Coolness. Change the U-joints too.
Old Mar 23, 2023 | 11:10 PM
Keith_L's Avatar
Keith_L
The bushing gets a little funky, check moparman1973 threads (search the web) for some tech. The casting numbers on your tailshaft housing can help you know which bushing you need.
Old Mar 24, 2023 | 09:24 AM
Braintanned
Ok thanks
Old Mar 24, 2023 | 10:32 AM
Braintanned
I tried putting the driveshaft in 180 degrees out from what it has been and the shaking was at least as bad, but moved to starting about 50 mph were it had been starting closer to 35.
Old Mar 24, 2023 | 10:45 AM
Just clocking the shaft doesn't really make any difference.....
Old Mar 24, 2023 | 10:51 AM
Braintanned
It certainly did, or something related.
Old Mar 24, 2023 | 11:05 AM
Likely something related. The shaft is still spinning in the same plane it was before, and there was no vibration with it absent. Of course, nothing in the rear diff was turning either.....
Old Mar 26, 2023 | 09:21 AM
Braintanned
The front axle isn't going to cause these symptoms in 2 wd right?
Old Mar 26, 2023 | 09:22 AM
Braintanned
