Shake/vibration in seat 45 mph
Old Mar 22, 2023 | 04:29 PM
Braintanned's Avatar
Braintanned
Default Shake/vibration in seat 45 mph
I bought .a 98 ram 1500 quad cab 4x4 a couple months ago.on test drive I could feel a vibration in seat and have been trying to troubleshoot it.i have removed driveshaft and was told by driveline specialist that u joints were good.i also rotated wheels and tires front to rear with no change.when I was initially trying to inspect u joints I noticed bad trans mount and replaced that.so now the problem continues..a shaking in seat and floor between 35 and about 55 mph.coasting, braking, putting trans in neutral do nothing to change it. There is fluid in the extension housing seal on the transfer case but I can't get movement there when pushing yoke. I would like to avoid throwing money at it and guessing if possible, but I don't know how to move forward with it.i was very surprised moving the tires didn't move the vibration to the steering wheel.there is also a noise kind of an oscillating wa wa wa noise that isn't real loud and could be tire noise but I don't think so. Suggestions?
Old Mar 22, 2023 | 05:57 PM
If you lightly apply the brakes, does the vibration change? Is the T-case in some flavor of 4x4?
Old Mar 22, 2023 | 06:06 PM
Braintanned
Braking or acceleration does nothing, other than to get out of the range it does it. In 2 hi.
It's really consistent and I've not found anything to make it change other than getting out of that mph range.my instinct says tire despite kind of ruling it out.
Old Mar 22, 2023 | 06:19 PM
I would tend to agree with you. Wouldn't hurt to have 'em checked/balanced.... maybe you have more than one that is bad.
Old Mar 22, 2023 | 07:54 PM
Braintanned
It doesn't make sense that I couldn't feel a bad front tire in the steering wheel before or after rotation though.
Old Mar 23, 2023 | 09:49 AM
Where did you get the idea that problems of this nature need to make sense?
If it was a front end problem, yes, you would indeed expect to feel it thru the steering wheel. Given that it happens in a specific speed range, regardless of other circumstances though, gotta be something in the driveline that spins... So, maybe an out of balance driveshaft, bad or sticky u-joints, or possibly a bearing in the rear diff. (though I would expect to be able to HEAR that.) One or two piece rear driveshaft on yours?
Old Mar 23, 2023 | 09:54 AM
Braintanned
One piece, steel driveshaft
Old Mar 23, 2023 | 10:08 AM
An interesting experiment might be to pull the rear shaft, put it in 4x4, and run it up to speed. See if the shake is gone. Gotta do something with the rear output though, else it will puke fluid, and empty the t-case right quick.... Maybe run it on jack stands?
Old Mar 23, 2023 | 10:31 AM
Braintanned
Exactly what I've been thinking and also run it on stands with the wheels removed and drums tightened down with a couple lug nuts.
Old Mar 23, 2023 | 10:37 AM
That would likely work.
