Misfire
Old Jun 17, 2023 | 12:35 AM
Sirriggs's Avatar
Sirriggs
Default Misfire
I did a quick spark plug change and it has improved a little I took a couple of pictures of some of the plugs. I really don't see anything really bad. It just seems driving at speed seems to feel like there is a misfire. Basically all electronic parts have been changed on throttle body. Did a full tune maybe around 8 months ago. I can't remember 100%. I bought and replace fuel injector's from1A Auto parts but ended up putting original back in after one or more failed after two months ( they started to dump fuel in cylinder). They just blew me off so wont but from them again. I know the tank is clean since I replaced the fuel pump maybe 6 months ago and clean the tank when it was out. Being it sat for about 5yrs, I expected some gremlins will surface here and there. I finally have the shifts a lot better and been driving it everyday so far to work and back. I really can't think of what to look for at this point on this misfire issue? I not sure if maybe one or more injectors may be causing the misfire or if maybe is some trash may be part of the issue? I blew out the lines when I did the replacement. Is it possible to clean fuel injectors? I have seen a few videos but have tried in the past and it didn't seem to work.
Old Jun 17, 2023 | 02:35 AM
Ramman18's Avatar
Ramman18
Injectors can be flow tested and cleaned at shops.
Plugs should be Champion. Anything else can run weird. Double check installation and plug wires/routing.
Auto trans can cause driving issues too.
Old Jun 17, 2023 | 05:39 AM
Moparite's Avatar
Moparite
What about the cap & rotor? Wires ok?
Old Jun 17, 2023 | 09:55 AM
Sirriggs's Avatar
Sirriggs
I did Champion copper plugs and did a full tune up awhile back so they are good. Not sure on how auto trans would effect misfire? I just rebuilt it around a month ago. Money little short right now for a shop. Getting 15 inches of rain with more coming has flooded my road making things rough. I don't have a timing light so just may have to rough it out. It's not real bad but enough to know something off a little. lol
Old Jun 17, 2023 | 10:18 AM
How is your crank sensor?
Old Jun 17, 2023 | 12:42 PM
Ramman18's Avatar
Ramman18
Trans doesn't cause misfire, it can act up and make it feel like misfire. I had a car with a weak converter and it chugged or stuttered when driving like a misfire.
Old Jun 17, 2023 | 12:57 PM
Sirriggs's Avatar
Sirriggs
Yeah, That's new
Old Jun 17, 2023 | 12:59 PM
Sirriggs's Avatar
Sirriggs
This was fully rebuilt with new convertor. I gave a couple of grey hair over my rebuild lol. The trans guy even noticed it was misfiring. Unfortunately because I rebuilt it. It seems doesn't want to get involved. I was having shifting issues then.
Old Jun 18, 2023 | 06:39 AM
Moparite's Avatar
Moparite
Any codes? Did you do the plenum gasket fix? Bad PCV valve?
Old Jun 18, 2023 | 08:55 AM
Sirriggs's Avatar
Sirriggs
No codes. I looked down the throttle body and clean as a whistle ( Did the upgrade plate). PVC was replaced. I will say it click's like crazy. I even change what looks like a PVC on driver side after I broke it trying to see if maybe it was clogged.
While idling it's little rough. While driving it will again do a light stumbling/misfire. It's not bad but you can feel it. Thanks guys
