Seemed fine yesterday then no start this morning and 5 codes. 95 obd1
Thanks. So spark is crank sensor and fuel is cam sensor? I guess I could buy one of those spark plug flasher/tester things and try filming it with my phone. How do you check for fuel under your shade tree....I have an oscilloscope.... maybe I could check injector pulses?
I bet its the crank sensor again. Those things seem like a pain on this truck.
It sure would be cool ($$$) to upgrade to the holley efi and their distributor that eliminates the factory cam and crank sensors.
hmmmm. I didn't used to get those transmission codes. Very strange. The first thing that jumps to my mind are conspiracy theories as usual
Trending Topics
Might be as simple as a questionable ground somewhere. I went thru three fuel pumps because of a bad ground. (I obviously took it to the wrong shop.....)
Well, if you are getting all those trans codes, your automatic trans obviously won't work properly. Probably why they gave ya that stick coming up out of the floor next to the tcase shifter.
On a more serious note, I don't think they will cause you any issues, aside from that annoying lite being on.
