Screwed up (literally)- bolt thread issues
Old Mar 9, 2024 | 07:04 PM
cas2023's Avatar
cas2023
Default Screwed up (literally)- bolt thread issues
As the title states, I screwed up. By that I mean that I might have cross threaded my distributor bolt and radiator trans cooling fitting. Just wrapping up after doing a cam and springs swap and plenum kit, and this is how I'm rewarded, right at the finish line. I was hoping to get it started up this weekend, but I might be looking at borrowing a die and thread set instead before I do anything else
What are my options for the distributor bolt? It's a HUGE pain in the rear to try and mess with, I've been trying to thread it straight for at least 3 hours, and it keeps wanting to catch the threads at an angle. I've been rinsing and repeating just trying to get it to bite straight down with no luck
Old Mar 9, 2024 | 08:17 PM
Get a tap into it, make sure it goes in straight, and clean up the threads. (put some grease on the tap, to catch the shavings.)
For the cooler line, should be able to replace that fitting......
Old Mar 9, 2024 | 08:28 PM
cas2023's Avatar
cas2023
Would you happen to know the thread specs for the bolt on the distributor plate? Thanks
Old Mar 9, 2024 | 08:30 PM
Look in the FAQ/DIY section, there are download links for parts manuals, get the one for your truck, find that bolt, and it should give you specs. I haven't had a truck with a distributor for several years now.
Old Mar 10, 2024 | 12:04 AM
Keith_L's Avatar
Keith_L
It's likely just photography playing tricks, but I swear that dist bolt is bent.
Just pull it out and measure it. If you don't have inexpensive calipers and thread pitch gauges, they're inexpensive and invaluable. Be sure to get both SAE and metric pitch gauges. In the meantime any hardware store or fastener house can help you.
I'm guessing 5/16‐18 because that's what the thermostat housing is <----- NOT a good reason!!
Old Mar 10, 2024 | 08:48 AM
Moparite's Avatar
Moparite
The threads are gone on the cooler(tip). I doubt you will be able to get a replacement to thread on to it.
Old Mar 10, 2024 | 08:55 AM
cas2023's Avatar
cas2023
Yeah, been looking for ways to remove the tip now. Is it a push-in type that fits in a rubber seal or is it threaded? If it's threaded I don't see any way to unscrew it unless I grab the threads and twist. Otherwise, I might just throw the whole radiator out lol, a lot less work to just put in a new one probably
Old Mar 10, 2024 | 11:36 AM
AtomicDog's Avatar
AtomicDog
If you're going to replace the radiator anyway, I'd suggest looking at an all-aluminum radiator as a replacement option. I've had my fill of leaks at the plastic tanks over the years with the OE style radiator
here's an example
https://www.ebay.com/itm/276087131997
Old Mar 10, 2024 | 12:34 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
The hose fitting is casted in the plastic tank and unremovable. That aluminimum radiator looks nice.
Old Mar 10, 2024 | 01:47 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
I installed an all-aluminum CSF 2969 radiator in my truck many years ago. It's still holding up well with no issues and was an easy bolt-in swap. Unfortunately, CSF no longer makes it, but there are plenty of other knock-offs are out there. Here is an old thread that discussed the CSF 2969 all-aluminum radiator - https://dodgeforum.com/forum/2nd-gen...-radiator.html
