Mystery misfire
Old 04-18-2024, 03:35 PM
Thompson098's Avatar
Thompson098
Thompson098 is offline
Default Mystery misfire
I have a 02 2500 with the 5.9 magnum with a misfire I can’t figure out. I changed the plugs, wires, coil pack, distributor cap, a good compression check and the injectors but it’s still misfiring off of multiple cylinders. Please help 😂
Old 04-18-2024, 03:49 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
What plugs did you install? How old are the O2 sensors? Done a compression test?
Old 04-19-2024, 06:49 AM
Moparite's Avatar
Moparite
Moparite is offline
Plenum gasket fixed?
Old 04-19-2024, 04:33 PM
Thompson098
the compression test was good and I put nkg iridium plugs in and I’m not sure how old the plugs are
Old 04-19-2024, 04:34 PM
Thompson098
that’s what I’m thinking my next move will be
Old 04-19-2024, 04:44 PM
HeyYou is offline
The plugs may be at least part of your problem. Change 'em out for some good copper plugs. These engines tend not to like the rare earth fellers.
The following users liked this post:
oddone (05-04-2024)
Old 04-19-2024, 05:21 PM
Thompson098
ill do that asap thank ya
Old 04-20-2024, 03:44 AM
Johnnyfresco's Avatar
Johnnyfresco
Johnnyfresco is offline
Default Plugs porcelain chipped tip!
If you're giving a code that says random misfire on a specific plugs. This just happened to us the other day random misfire on 2 and 7. That's all it said. So we pulled the plug and the porcelain near the tip of the spark plug had been chipped. Hope this helps if not it may help someone else in the future. Have a good day
Quick Reply: Mystery misfire
