1999 Dodge ram 1500,”No Bus” flashing and Abs light, check engine, airbag light
Old 07-21-2024, 04:03 PM
Woopty23's Avatar
Woopty23
Woopty23 is offline
Default 99 dodge1500,”No Bus” and Abs light, check engine, airbag light
Cant seem to figure out whats wrong with my truck, the check engine light is p0500 ive replaced the sensor on the rear axle and transmission,ohms read fine at the axle connector, Ive traced cables, im not getting any drops throughout, im at a loss. I just finished looking into the fuse box under the hood for corrosion
Old 07-21-2024, 07:57 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,335 Likes on 3,077 Posts
Vehicle speed sensor. On yours, that's the sensor on the rear axle. Unplug it, does the no bus go away?
Old 07-21-2024, 09:52 PM
Woopty23's Avatar
Woopty23
Woopty23 is offline
no, it stays the same.
Old 07-22-2024, 07:48 AM
HeyYou is offline
You have something else on the 5 volt bus failing then. Start unplugging sensors, see if one of 'em gets the dash back.
Old 07-24-2024, 02:37 PM
Woopty23's Avatar
Woopty23
Woopty23 is offline
I disconnected the Vss sensor, transmission tail shaft sensor, and the abs module. The same lights are still on. I might also mention I replaced all 3 sensors, what would u recommend I disconnect next?
Old 07-24-2024, 04:12 PM
HeyYou is offline
Anything on the 5 volt bus. Which is also most of the engine sensors.
Old 07-24-2024, 05:34 PM
Woopty23's Avatar
Woopty23
Woopty23 is offline
[QUOTE=HeyYou;3591257]Anything on the 5 volt bus. Which is also most of the engine sensors.[/QUOTE
Is there anything i can do to rule out where i should start disconnecting?
Old 07-24-2024, 06:45 PM
Woopty23's Avatar
Woopty23
Woopty23 is offline
update: I disconnected crankshaft sensor,MAP sensor, TPS sensor. Still the same issues.
Old 07-24-2024, 09:22 PM
HeyYou is offline
Try front and rear O2 sensors as well.
Old 07-25-2024, 12:33 AM
Woopty23's Avatar
Woopty23
Woopty23 is offline
Thank you i will try that tomorrow, i also tested everything I disconnected with a multi meter and got 5v. Also when i drive around and look on my code reader the VSS will cut out and drop to 0 at times
Quick Reply: 1999 Dodge ram 1500,”No Bus” flashing and Abs light, check engine, airbag light
