new tires and leveling kit
Hello everyone,
I just put a set of Mickey Thompson 305/70r16s (33x12.5) on my 1999 Ram 1500 4x4 Sport. The front tires are rubbing a little on the plastic inner fender when pulling into parking places. I am wondering if the 2” leveling kit will cure this problem. Are Leveling kits and Coil Spring Spacers the same thing? Would I be better off going with new 2” lift coil springs. With either option will I need any other parts (Shocks, steering stabilizer, etc)?
I welcome and appreciate any comments or suggestions.
THANKS
THANKS
RE: new tires and leveling kit
yes they are the same.
and get them, if you ever decide to go with a taller lift you can use them to gain more lift or use them to trade or sell for higher lift parts. The 3" coils are hard to get rid of and still make anything off of.
The spacer on the other hand people use to gain 2 more inches of lift with 5" or 7" coils.
supply and demand.
supply and demand.
wait so did you put the tires on a stock 99 ram cause i didnt think they would fit with the stock suspension, if you did did you use the stock rims? i wanted to know how big i could go with a stock truck cause i got a 99 4x4, if you did, do you got any pics? i would love to see how they look!
Hello,
Yes the 305/70r16 look really nice under the truck. Its a stock 99 Ram 1500 regular cab Sport. The tires are on the MT Classic II rims. They stick out past the fender about one inch. The only problem I am having is the drivers side is rubbing the innner fender making sharp left turns. It only rubs a little, and I can see the "clean" spot it has left on the fender well. I will try to post a few pictures on Monday.
Trending Topics
Hello,
Attached are the pictures. The 305/70r16s are rubbing the inner wheel well when making sharp left turns. Thanks for everyones comments. I think the leveling kit is what I need.
[IMG]local://upfiles/18108/44B6446D26044701A849BE18420BE870.jpg[/IMG]
[IMG]local://upfiles/18108/F9FBF953F9F549E68FDF688EC49BB499.jpg[/IMG]
[IMG]local://upfiles/18108/CB0089616A6146F4BAAE7AE7CEF914EC.jpg[/IMG]
