ABS and Brake light
#21
I get code 9. High resistance or open circuit to the speed sensor.
I checked the wires between the speed sensor and the brake controller. Checked fuses and terminals for corrosion and dirt. Everything was good. I guess the speed sensor might be failing sometimes. So i'll replace it and see what happens. If not i'll just remove the light bulbs and pass my safety inspection that way (did it before on my Grand AM with abs and brake light on!)
#22
#25
