K&N FIPK No More
Old 01-10-2007, 02:14 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
Default RE: K&N FIPK No More
ORIGINAL: ripto
Silver, you have a flat base right? What is the height of your new K&N, I don't think you mentioned it, I know you said the possible heights but don't think you said the one you have now. I have to go with a smaller filter, I don't know why this 3" won't fit in my truck.
For everyone, are the bottom parts of your base curved in? Mine is like an L shape around the bottom, the part that sits on top of the gasket on top of the TB, doesn't seem like it makes a good seal.
My base is flat I think, but I can't remember for sure. I'll try to get some pics. The paper filter that comes with mine is 12.75" x 2.75". I am running that and think it performs fine. I did fit a K&N that was 2.87" with no issues. I am trying to find a company that makes a 12.75" x 3", but if I don't, I don't care because it is working great the way it is.
  #162
Old 01-10-2007, 02:19 PM
ripto's Avatar
ripto
ripto is offline
Measured with a ruler, the outside height is 2-15/16" and the inside height is 3"
[IMG]local://upfiles/21486/B8B6FC9E53BA43DAB0CBC83888CFB10C.jpg[/IMG]
  #163
Old 01-10-2007, 02:23 PM
ripto's Avatar
ripto
ripto is offline
ORIGINAL: Silver_Dodge
Oh okay, mine is 13-15/16" x 3".
  #164
Old 01-10-2007, 02:37 PM
Silver_Dodge
Ya, remember, I have the Mopar assembly, not the K&N/Mr. Gasket/Edelbrock 14" assembly. A 3" filter would still be tight on mine though.
  #165
Old 01-10-2007, 02:41 PM
ripto's Avatar
ripto
ripto is offline
Yea true, I think I might try for the Mr. Gasket 14x2.5 setup, #1480
http://store.summitracing.com/partde...p;autoview=sku
  #166
Old 01-10-2007, 05:09 PM
Ramdamit98's Avatar
Ramdamit98
Ramdamit98 is offline
I'm running the Mopar Performance Assemebly and it's actually a 1/4 inch rise base. All I have is the paper filter in for now that measures 2.75". That ends upbeing 3" from the throttle body.It's a tight fit and I tied up the wiring harness like ASH to give it a little room. I had to put eveything together halfway on(over the s-bolt, but not over the rest of the throttle body)and then lift the whole unit (including the base) onto the bolt and the throttle body.
  #167
Old 01-10-2007, 05:38 PM
Silver_Dodge
I put the base on, then the filter, then the s-bolt, then the top. When I remove the filter, I take the top off, remove the s-bolt, and the filter slides straight out. Takes about 30 seconds total.
  #168
Old 01-10-2007, 05:58 PM
ripto's Avatar
ripto
ripto is offline
Did you have to use a nut on the s-bolt to keep it at a certain height since the fastman doesn't have that stuff around the bores?
  #169
Old 01-10-2007, 06:02 PM
Silver_Dodge
No, I just count how many turns it takes to unscrew it, and when I put it back in, I screw it in the same number of turns. A bolt would probably work good too though because then it would just stop at that same point when the bolt touches the TB. Good idea.
  #170
ASH's Avatar
ASH
ASH is offline
I ported my own TB, but did not grind the stub down where you thread in the S-bolt. Even with the extra depth for threading in the S-bolt,I still use a nut to lock it into place. The main reason isthe S-bolt does not seat when it is lined up with the hole in the air filter cover. So I use the nut to lock the bolt into position.
Quick Reply: K&N FIPK No More
