Old Aug 5, 2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Pulled My Transfer Case (Pics)
Old Nov 10, 2010 | 05:54 PM
  #31
95RAM360's Avatar
95RAM360
edit...
heres the spider cracks
Old Nov 10, 2010 | 06:47 PM
  #32
J415's Avatar
J415
without a doubt...change it!
Old Nov 10, 2010 | 06:48 PM
  #33
merc225hp's Avatar
merc225hp
So do these look familiar, They aren't "spider" cracks those are the casting marks from when the case was made, We all have them on the T case. Some more some less.
Note: Please don't tell me I need a new case as well it's the way they are made.
I would like to see some pic's of the gears and chain
Old Nov 10, 2010 | 08:48 PM
  #34
95RAM360's Avatar
95RAM360
well my cracks go all the way through, i have the t-case in half right now, and can see the other side.....mine is cracked all the way through, and everywhere....that pic is only like a 6inx6in section of the t-case.....the rest is cracked as well....and i found broken pieces in the inside of the t-case.....so i know those must have been slammed against the casing.
Old Nov 10, 2010 | 09:21 PM
  #35
J415's Avatar
J415
If those were casting marks, then they'd all be identical.A couple more heavy heat cycles and that suckers gonna crack.
Old Nov 10, 2010 | 10:51 PM
  #36
merc225hp's Avatar
merc225hp
It's called sand casting and no two are ever the same. Sorry for wasting your time, Good luck.
Old Nov 11, 2010 | 09:50 AM
  #37
95RAM360's Avatar
95RAM360
ive overheated my tranny about 5 times (while in 4x4) so could that be the cause of the cracks, is the heat?
Old Nov 11, 2010 | 10:20 AM
  #38
overheating the trans shouldn't really affect the transfer case. the biggest problem with the t/c in these trucks in the output shaft snap ring breaking, and then parts wandering around inside the case, destroying it, and themselves.
