Performance Intake
Old 06-07-2007, 01:03 AM
slaterracing's Avatar
slaterracing
slaterracing is offline
Default Performance Intake
OK has anyone run this intake set up?
I know it is a cheap e-bay intake but i like the look of it. Or should i just bite the bullit and get a K&N FIPK. I know it has the heat sheild so it is going help but $250 vs. $50 is a big diff.
Old 06-07-2007, 01:10 AM
turbot_bird's Avatar
turbot_bird
turbot_bird is offline
Default RE: Performance Intake
it will flow better than stock but heat rises and those filters are right above both manifolds
Old 06-07-2007, 01:13 AM
slaterracing
ORIGINAL: turbot_bird
if i go with the twin set up i was also going to get the heat shields that attach to the filters to help that. most of it is the look. i just like the twin snorkle look and it is $50 kinda hard to beat that.
Old 06-07-2007, 01:36 AM
turbot_bird
well, mostly what I was talking about is the hot air of the engine bay, the gains form airflow will probably be working against the loss because of the hotter air
Old 06-07-2007, 01:57 AM
rookie's Avatar
rookie
rookie is offline
I'm afraid you'llbe forcedto employ the use of a "ram air" hood. Poor you. you know you want one!
Old 06-07-2007, 02:02 AM
slaterracing
ORIGINAL: rookie
how did you know i was on goodmark's site looking at those?
Old 06-07-2007, 02:11 AM
curtiplas's Avatar
curtiplas
curtiplas is offline
Yeah I'd go with a K&N... or do a ram air hood...better yet get the real shaker hood :-P
rookie's Avatar
rookie
rookie is offline
I'd turn it up-side-down. Have it pokin' out of the hood on either side.
Old 06-07-2007, 02:41 AM
Altair's Avatar
Altair
Altair is offline
Dak attack!
ORIGINAL: rookie
Then tie a set of steer horns on the front of the hood with rope
Quick Reply: Performance Intake
