How far on reserve
Old Sep 13, 2007 | 06:22 PM
Cuban11182's Avatar
Cuban11182
Default How far on reserve
How far have you gone on reserve? Anyone run out of fuel?
Old Sep 13, 2007 | 06:49 PM
xx1479's Avatar
xx1479
Default RE: How far on reserve
You got about 4 gallons when the light comes on. Depends on your gas mileage.
Old Sep 13, 2007 | 07:06 PM
Frenchy's Avatar
Frenchy
Do you have the overhead? I think I read in my manual that once the overhead reads zero you have like 11% of your tank left... or bout 2.3 gallons...
Old Sep 13, 2007 | 09:42 PM
trucky's Avatar
trucky
I RAN OUT! proud of it. i was full of passengers and the needle was on rock bottom AND i was on a deep slant when it happened. and they (the air force base police)wouldnt tow me cuz i was 'out of juristiction' (by 20 feet). but its ok i got a little gas tank and just started it back up.
anyways, when the needle is on the bottom it goes pretty far, i just wasnt used to have 4 people with me and going up a big hill....learned my lesson
Old Sep 13, 2007 | 10:00 PM
Frenchy's Avatar
Frenchy
Uhmmmm, you shoulda pushed it the 20 feet....
Or maybe thats just me thinking?
Lol
Old Sep 14, 2007 | 08:44 PM
Nocturnal's Avatar
Nocturnal
I've never run out, but been scared a few times. My guage reads a little off since I put my airbags on the back and I tow a lot off and on. So watching my mileage doesn't work well. What I did was buy a 2.5 gallon gas can, one of the vapor less ones, and I keep it full and in my tool box at all times. Only had to use it once and boy was I happy to have it there. Probably not the right answer, but it works for me.
Old Sep 14, 2007 | 08:50 PM
superdak05's Avatar
superdak05
i hit 380 miles on the overhead and the light comes on, then when i fill it up about 20.5 gallons it takes.
Old Sep 15, 2007 | 12:39 AM
mb18's Avatar
mb18
The most I've ever put in is a little over 20 gallons....I don't often let it run low....
I usually get between 280-350 per tank, depending on what I'm doing....if it's towing, it's closer to the 280 or less.
Old Sep 15, 2007 | 12:50 AM
JAB02LHS's Avatar
JAB02LHS
About two gallons when filled with light on.
Old Sep 15, 2007 | 03:14 AM
Altair's Avatar
Altair
Dak attack!
ORIGINAL: Nocturnal
Just stop and fill up a bit before it gets near empty. Your bladder will thank you for the relief and your truck will thank you for not straining the fuel pump
