Sonofabeach
Old Mar 20, 2009 | 05:40 PM
TRX4_2008's Avatar
TRX4_2008
Default Sonofabeach
Ok.... had spare time today. Installed the 2" leving kit, then the new wheels and tires I bought months ago. 2 problems:
#1 Stock was 265/70/16. I used 265/75/16 MTZ's and they rub BAD! What's the answer there? Sawzall a corner of the inner well off?
#2 Stupid tire pressure sensors. Didn't even know I had them in the Dak, so now I got ding ding ding ding going on?
Suggestions please???
Old Mar 20, 2009 | 05:52 PM
coondog05's Avatar
coondog05
wheres the rub? if its just the front id use zip ties and pull the well in to the frame and i cut the back mudflap/flare straight down on mine with some tin snip type cutters...dont go crazy it only takes a little trim to get the tire to clear when at full lock...you wont ever notice unless you point it out to someone....
Old Mar 20, 2009 | 06:39 PM
superdak05's Avatar
superdak05
as for the sensors, pull the fuse, but the idiot light will show on the dash board.
Old Mar 20, 2009 | 06:50 PM
Damn Dirty Ape's Avatar
Damn Dirty Ape
Can you post some before/after pics of your kit and wheels? We always like to see those
Old Mar 20, 2009 | 08:05 PM
TRX4_2008's Avatar
TRX4_2008
Ok.... got the rub fixed. My daughter came home, so I had her inside turning the wheel. It was in the FRONT INSIDE of both wheel wells. I cut an inch off diagnal with a sawzall, cleaned up with an angle grinder. You'd have to be a rocket scientist to find it. Can't tell.
Next... I'm being told by a buddy in auto service that there is no fuse for tire sensors, and can't be over ridden. I find this hard to believe. I checked the fuse box, if it's there I have no idea how its labled. Any ideas? This is an 08.
Ok, heres a few pics, but weather is awful here. 1st, stock tires, no lift. 2nd, stock tires WITH lift. 3rd & 4th new tires/wheels WITH lift. 5th, just thought I'd toss in my Rhino Liner and BedRug.
Old Mar 20, 2009 | 08:17 PM
Altair's Avatar
Altair
Dak attack!
Looks good! I'm running the same size tires you are and I only get a tiny bit of rubbing at a certain angle but it's not enough to bother with. Your tires have a much more aggressive tread than mine though so I'd imagine that's why yours rub more.
Old Mar 20, 2009 | 08:56 PM
Damn Dirty Ape
What leveling kit did you use? any issues or notes on the install for a fellow trx4 owner?
Old Mar 20, 2009 | 10:48 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Man that looks great. Awesome. It must be the new wheels that are causing the rub. Backspacing or somthing. Either way, that sh*t looks awesome.
Old Mar 20, 2009 | 10:59 PM
mprohr's Avatar
mprohr
Nice truck man. I've gotta say, I wish you had those tires on the stock rims. I've always had a hard time warming-up to tri-spokes. I do dig the bed rug.
Old Mar 21, 2009 | 06:56 AM
TRX4_2008's Avatar
TRX4_2008
Damn Dirty: The kit I used was one of those solid aluminum blocks for $89.00 on Ebay. It was an easy install. On the wheels.... I started a thread a few months ago with 2 wheels to choose from. Everyone voted for the other wheel, so I went with these to be different. The rub issue was easily resolved and not noticable at all. The aggressive lugs on the tire are what was rubbing on a full turn. All better now.
Does anyone know a way to disable that darn tire sensor? Fuse? Relay? Cut a wire?
If I can't get that issue resolved, I may have to try breaking down both sets of tires and see if can install the sensors on the new wheels. I may check the stealer to see how much the sensors are too.
