Emblem Removal?
Old 07-17-2009, 02:27 PM
nola24's Avatar
nola24
nola24 is offline
Default Emblem Removal?
I want to give my truck a more custom look, and was wondering what the proper way to remove the plastic dodge, V8, and SLT logos. I remember there being a post in the DIY section, but I can't find it.
Thanks,
Kyle
Old 07-17-2009, 02:49 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
If it's not in this FAQ section, I've got a DIY in the 3rd Gen Ram FAQ section on it...
Old 07-17-2009, 02:50 PM
biker_ahoy's Avatar
biker_ahoy
biker_ahoy is offline
Old 07-17-2009, 08:49 PM
projektdirtfab's Avatar
projektdirtfab
projektdirtfab is offline
decal remover and dental floss works great as well..
Old 07-17-2009, 10:58 PM
Altair's Avatar
Altair
Altair is offline
Dak attack!
You must buy some extremely strong dental floss, I gave that a shot first when I debadged mine and it kept snapping.
Old 07-18-2009, 12:04 AM
Blown287's Avatar
Blown287
Blown287 is offline
It also helps if you heat the emblem with a hair dryer or heat gun. You don't want it to hot, just enough the dental floss will slice through it. Good luck.
Old 07-18-2009, 12:35 AM
superdak05's Avatar
superdak05
superdak05 is offline
dont use floss, get some fishing line, it is stronger. and yes heating the emblem will make it easier to remove
Old 07-18-2009, 12:43 AM
Blown287's Avatar
Blown287
Blown287 is offline
You know what? I think I did use fishing line.
Old 07-18-2009, 08:37 AM
paul05dak's Avatar
paul05dak
paul05dak is offline
fishing line, heat, goof off, patience (don't want to scratch the paint) and I also used a old credit card. (to scrape with, not to pay someone.) then wax it really good when your done. Depending on the color of your truck and how long it's been in the sun, you may see a little difference in the color where the decals were. in a couple of weeks, that will blend right in with more exposure to the sun.
Old 07-18-2009, 11:05 AM
Altair's Avatar
Altair
Altair is offline
Dak attack!
I definitely recommend getting the eraser wheel and using Hammer's method vs. using goof off or something else to get the residue off. It will make your job much easier, I wish I'd known about that when I did mine.
If you don't use that I would pick up some 3M General Purpose Adhesive Remover. You can get it at most auto parts stores and it is designed to be safe for paint. Personally I'm a bit wary of using goof-off on my paint, I've seen it start dissolving and bubbling plastic before I can't imagine it's too kind to paint either. I heated my emblems and then squirted some of the adhesive remover behind to soak into the adhesive before I started in with the fishing line (after the first failed attempt with floss, lol). If you take your time using this and a soft cloth you will be able to get the residue off without using a scraper, most wholesale clubs (BJ's, Costco, etc) sell large packs of microfiber cloths for around $10 that won't scratch your paint.
Whichever method you use be sure to wash the area off and hit it with some wax after you're done and good luck
Quick Reply: Emblem Removal?
