Tuner, Which one?
Old Feb 12, 2010 | 10:53 PM
ssenay's Avatar
ssenay
Default Tuner, Which one?
Looking to buy a tuner, which one do you guys recommend? Easiest to use and update?
4.7 2006 Dakota
Old Feb 12, 2010 | 11:02 PM
bain64's Avatar
bain64
I'm happy with my Superchips 3865, but its the only one i've used. I also have an 06 4.7
https://www.superchips.com
Old Feb 12, 2010 | 11:36 PM
Blown287's Avatar
Blown287
If you plan on major mods that require custom tuning go with SCT or Diablo Sport. If you not, go with Superchips.
Old Feb 13, 2010 | 07:33 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Thats what I say too Blown, for the avg consumer that just wants an edge, then Superchips... if fully custom, SCT or Diablo. The chips are all basically plug in and follow the on screen commands. I know with the Superchips they have a program that you download on to your computer for updating, so you basically plug the tuner in via USB for the updates. Simplest you can get.
I am super happy with my Superchips 3865. I think its the best mod I have bought.
Old Feb 13, 2010 | 10:20 AM
ssenay's Avatar
ssenay
Well i have a k&n CAI, magnaflow cat back, Fastman TB (coming), electric fan (on the way also) and currently have a jet chip on it.
I thought about doing HO cams also. But i may not.
That said still use the superchips?
Old Feb 13, 2010 | 10:29 AM
lghtngblt02
As far as just the CAI, Exhaust, TB, and Fan, Superchips is still competitive. Bumping up to cams, you might as well go with SCT or Diablo, you'll get more out of the cams. The jet chip is no comparison to the tuners. If I remember right, I believe Superchips even states best results are found with an intake and exhaust. A fan just makes it so much easier for the engine to turn... theres no clutch fan drag. The TB is just opening up the intake side, as well, increasing flow and such.
Old Feb 13, 2010 | 10:59 AM
Blown287's Avatar
Blown287
Well i have a k&n CAI, magnaflow cat back, Fastman TB (coming), electric fan (on the way also) and currently have a jet chip on it. I thought about doing HO cams also. But i may not. That said still use the superchips?
Those are not major modifications so a Superchips will work fine. Major Modifications are 206-224 Cam swaps, turbos, superchargers, nitrous, boring the cylinders .040 etc. If you plan on major mods they will require specific tuning.
Before the supercharger/alky/cams/bigger injectors I used a Superchips. The Superchips could not support these tunes so I went to SCT.
Old Feb 13, 2010 | 12:17 PM
ssenay's Avatar
ssenay
Ok thanks guys, looks like i will pick up a superchips this week. What if i swapped to just the HO cams, would that still be ok?
Old Feb 13, 2010 | 04:35 PM
Blown287's Avatar
Blown287
Yes, HO cams and 206 you can safely run while using a Superchips. If you go to 212, it is a must to run custom tunes. With 206 cams, you won't even feel them without a cam specific tune.
Old Feb 13, 2010 | 04:36 PM
Jaded's Avatar
Jaded
Did superchips ever give us that stock shift option they promised? I haven't checked and mine has been sitting on the shelf for some time, may put it up for sale.
