HHR Fan Installed
Old Sep 13, 2010 | 05:36 PM
  #131
hendrixx324's Avatar
hendrixx324
that must be it because i feel like my alt is struggling. I stil have the fan so when i start working again. ill try the spal controller. how does the spal work? does it multiply the power going through it.
Old Sep 13, 2010 | 05:47 PM
  #132
Blown287's Avatar
Blown287
The SPAL actually increases signal intensity to the fan making it spin faster. The fan is powered directly from the battery.
Old Sep 13, 2010 | 05:51 PM
  #133
hendrixx324
ok well thats probely why it wasnt working because i thought it woulda worked better then my clutch fan. when i start working ill redo it. hopefully make it look alittle cleaner.
Old Sep 15, 2010 | 02:49 AM
  #134
ozone45212's Avatar
ozone45212
Question SPAL makes the fan faster?
Blown, are you saying that the SPAL controller boosts signal so the fan works harder than the set up I and Newmexico have?
Old Sep 15, 2010 | 07:25 PM
  #135
Eimer123's Avatar
Eimer123
WOOHOO UPS!
Old Sep 15, 2010 | 10:02 PM
  #136
ruger226's Avatar
ruger226
Talking
[quote=Eimer123;2264414]WOOHOO UPS!
just ordered mine yesterday should be here by next week im so pumped!
Old Sep 15, 2010 | 10:04 PM
  #137
ruger226's Avatar
ruger226
How much rwhp do you actually gain if any from this?
Old Sep 15, 2010 | 10:49 PM
  #138
Eimer123's Avatar
Eimer123
I have heard it will free up about 10 HP, but that seams kinda high to me, probably better throttle response.
You will remove some parasitic loss from the engine.
Old Sep 16, 2010 | 06:10 PM
  #139
donkeypunch's Avatar
donkeypunch
King Jackass
Mine just arrived today, and just installed it.
Blown, did you block off the sides (open areas, about .800" wide, and go down the both sides of the fan shroud.)?
For those of you wanting to know if the Spal controller is worth it...it is. I am very impressed with the easability of installation and programming. This makes drivability a breeze.
Old Sep 17, 2010 | 07:42 PM
  #140
ruger226's Avatar
ruger226
Originally Posted by donkeypunch
Mine just arrived today, and just installed .
breeze.
I just installed mine today and left the gaps open and it worked just fine the temp gauge never went over half. How cool does it keep your truck with the gaurds on the side?
