HHR Fan Installed
Old Jun 8, 2011 | 08:19 PM
  #181
sullysdetailing's Avatar
sullysdetailing
Just got my HHR Efan and Derale controller today installing next Saturday
Old Jun 8, 2011 | 10:05 PM
  #182
wingman_214's Avatar
wingman_214
Take some pics while your at it.
Old Jul 31, 2011 | 07:00 PM
  #183
dbilik's Avatar
dbilik
Got the entire system setup in my truck right now, one last wire to hook up. The orange wire from the SPAL unit. Where did you end up tapping in to get +12 V only when the ignition is switched on?
Old Jul 31, 2011 | 08:17 PM
  #184
Hammond_Egger's Avatar
Hammond_Egger
Most of us used an add a fuse kit off the heated seat fuse (the one next to the fuse puller):
Old Aug 1, 2011 | 12:32 AM
  #185
wingman_214
Yep, that's the correct place to get power.
The blue/green wire at the top is where the ac referance comes from. I used a mini fuse tap.
Old Aug 1, 2011 | 06:28 PM
  #186
Ueland's Avatar
Ueland
Originally Posted by wingman_214
The blue/green wire at the top is where the ac reference comes from. I used a mini fuse tap.
That AC Relay Setup looks very farmiliar...
Old Aug 2, 2011 | 11:46 AM
  #187
wingman_214
Immatation is the sincerest for of flattery...great minds think alike.. Occam's razor.
Old Aug 11, 2011 | 10:03 PM
  #188
magnethead's Avatar
magnethead
I like this idea. going to set mine up to come on low with ignition, and high via rocker switch in cab.
Old Aug 11, 2011 | 10:34 PM
  #189
wingman_214
The controler is the way to go. It doesn't rob power from the ignition its only referance. It also uses a fuse for the fan so it doesn't break some thing. Adj Temp presets and referance from the ac.
For the power to the controler.
http://m.oreillyauto.com/mt/www.orei...n_jtt_redirect
The fuse tap is for the ac signal.
I hope the links work. I'm posting from my phone on South Padre Island.
Old Aug 11, 2011 | 11:00 PM
  #190
magnethead's Avatar
magnethead
sorry, no they're not. Here's what I came up with (column 2 from the left):
This runs the fan on low speed any time the ignition is on, and a switch on the dashboard flips it over to high speed.
