HHR Fan Installed
Old Apr 12, 2011 | 08:21 PM
  #171
Blown287's Avatar
Blown287
That is just for pressure. If you drill a hole in the new T-stat wit will do exactly the same thing.
Old Apr 12, 2011 | 08:33 PM
  #172
Dakkkota's Avatar
Dakkkota
should i???
where??
how big??? 1/8 1/4 ???
Old Apr 12, 2011 | 08:36 PM
  #173
Eimer123's Avatar
Eimer123
Originally Posted by Dakkkota
OK i bought the stant 13008 (5,2/5,9 engines)
and i compare it at the autopart to the one that is supposed to fit my truck(4,7 2006 dakota)...
they were alot different?? the stock one had a hole with a checkvalve on the side and the notch on the thermostat was useless because the gasket dont have the dent inside??? why the stock remplacement is SO different than the pic you shown me??
I am so confused about what you are asking. Maybe break up your questions and rephrase.
The stock replacement for our truck works just fine, will come with the notch, will come with the pressure relief hole with the ball in it, and just cost you an arm and a leg.
If you want to save money buy the 5.2/5.9 engine t-stat 54mm or 2.125", and grind the notch yourself. If you want the pressure relief hole, just drill one.
Old Apr 12, 2011 | 09:06 PM
  #174
wingman_214's Avatar
wingman_214
That hole with a check valve is known as a "jiggle valve", it there to prevent air from getting trapped in the system. Making a 1/8th" hole and installing the new thermostat with the hole "up" will be fine.
Old Apr 15, 2011 | 04:18 PM
  #175
Dakkkota's Avatar
Dakkkota
tomorrow morning :P
how much prestone will i loose in i just install the sensor
had if i remplace the thermostat do i need to drain the rad completely???
Old Apr 15, 2011 | 04:27 PM
  #176
Blown287's Avatar
Blown287
Might as well, it's going to start draining once you unbolt the thermostat housing. Since the hose is at the bottom of the radiator, your best bet is to just drain the radiator before you start.
Old Apr 19, 2011 | 02:24 PM
  #177
Dakkkota's Avatar
Dakkkota
i just finished to trim the dodge shroud and fit it to the HHR like ueland really cleen installation.
now the pt189/1210117 is not in stock and is special order 50$ so i am looking at a remplacement waterproof connector and cut the stock HHR plug off
Old Apr 19, 2011 | 02:59 PM
  #178
wingman_214
Borg Warner PT299, Niehoff PS38051, or Standard Motor Products S568 are interchangeable.
Old Apr 21, 2011 | 02:31 AM
  #179
Blown287's Avatar
Blown287
You don't have to use those, I just wanted it to look factory. Good luck man.
Old Jun 5, 2011 | 12:33 AM
  #180
sleds's Avatar
sleds
Summers coming. Time to bump this thread. Just working on my efan install right now. Replacing the t-stat right now.
