HHR Fan Installed
Old Aug 25, 2010 | 11:45 AM
  #61
newmexicoram's Avatar
newmexicoram
Originally Posted by ozone45212
The spal controllers I saw on ebay were $$$. Do I need something like that or would a universal fan controller work? Say, something like this?
http://www.autozone.com/autozone/acc...ier=196641_0_0_
think this one, (below) would work better.
http://www.autozone.com/autozone/cat...oductId=487016
or am I missing something?
I ended up using Auto Zone, TorqFlo Adjustable Electric Fan Thermostat part # 733647. Cost $35 and works great.
Old Aug 25, 2010 | 12:56 PM
  #62
sullysdetailing's Avatar
sullysdetailing
Blow what Spal wire kit do we need. What temp does the stock thermo open up at. Can we wire the fan up so we can turn it on and off when I please and that I dont need it to be hooked up with the stock thermo?
Old Aug 25, 2010 | 04:31 PM
  #63
Blown287's Avatar
Blown287
Originally Posted by WTEBOY703
hey blown have you sold your old e-fan yet? and does that one come with the ncessary hardware to instal?
Sorry man, its currently cooling Trucky's engine, lol.
I'm using the SPAL PMW but there are newer versions.
The stock thermostat runs at about 200 degrees. Most people prefer to use a 180 T stat instead.
Yes, you can wire a toggle switch for on and off.
Some controllers let you piggyback off the stock water temperature sensor. Others come with their own sensor.
Old Aug 25, 2010 | 05:15 PM
  #64
sullysdetailing
How did you hook yours up
Old Aug 25, 2010 | 07:21 PM
  #65
Blown287's Avatar
Blown287
Mine is piggybacking off the stock water temperature sensor.
Old Aug 25, 2010 | 08:28 PM
  #66
newmexicoram
Are you saying we can cut off the temp'. probe and put a connector on the probe wire and piggyback it to the stock temp'. sending unit?
Old Aug 25, 2010 | 10:26 PM
  #67
Blown287's Avatar
Blown287
It all depends on the sensitivity of the controller. With the one you have, I would not cut off the water temp probe, especially if its already in the radiator. The SPAL and other controllers have the ability to tap into the stock OEM sensor inputs.
Check it out, here is the tech manual for my SPAL.
http://www.spal-usa.com/fans/automat...ets/PWMIns.pdf
Old Aug 26, 2010 | 12:11 AM
  #68
ozone45212's Avatar
ozone45212
Red face
Thanks, Newmexicodak.
Blown, not to get off the subject of the fan, but you mentioned an aftermarket water pump? I had thought about this. Which one are you looking at, do you have a link to it?
Old Aug 26, 2010 | 12:23 AM
  #69
Blown287's Avatar
Blown287
Thread where I installed mine
https://dodgeforum.com/forum/3rd-gen...-heads-13.html
Here you go
www.gmb.net/html/products/waterpumps/HighPerformance.htm
For sale
http://www.racepages.com/products/?N...x=0&submit.y=0
Old Aug 26, 2010 | 12:25 PM
  #70
sullysdetailing
Blown is the HHR fan off the 2.2/2.4L ?
