power outlets....
Old 07-09-2010, 08:18 PM
SlvrKota22's Avatar
SlvrKota22
SlvrKota22 is offline
Default power outlets....
Why is that our power outlets for cell phone chargers do not continuie to charge when the truck is not running. My old ranger would charge a cell phone all day long with no stress on the battery... is there a way I can get my 07 to continue charging after its turned off?
Old 07-09-2010, 08:27 PM
Buckmaster's Avatar
Buckmaster
Buckmaster is offline
Does your truck have a center console with a power outlet inside of the console?
If so, it should be direct power.
Old 07-09-2010, 08:33 PM
Cuban11182's Avatar
Cuban11182
Cuban11182 is offline
you could change the wire to an always hot, like the constant on for the radio
Old 07-09-2010, 09:13 PM
jkeaton is offline
Dodge Forum Administrator
If you have the center console, the one inside is always powered.
Old 07-09-2010, 09:15 PM
Brian9's Avatar
Brian9
Brian9 is offline
I agree. On my truck the power outlet inside the center console will charge/power what I have plugged into it even if the truck is not running/on, however the one in the dash will not.
Old 07-09-2010, 09:30 PM
dakota_raven's Avatar
dakota_raven
dakota_raven is offline
Old 07-09-2010, 09:53 PM
SlvrKota22's Avatar
SlvrKota22
Alright I remembered that I had one in there the other day right after I gave my phone charger to my wife so I have not had a chance to test it but thanks for assuring me...
Old 07-09-2010, 10:11 PM
Moneyman19's Avatar
Moneyman19
Moneyman19 is offline
if u want it to be hot just pop the hood look into the fuse box ur power outlit on the sah u can change to make hot all the time. just read for that one and just switch it... ive done it before. better then running wires. lol
Old 07-10-2010, 09:18 AM
SlvrKota22's Avatar
SlvrKota22
I think if the one in my console works all the time I'm not gonna sweat changing the other one...
Old 07-10-2010, 12:49 PM
Robk1971's Avatar
Robk1971
Robk1971 is offline
If you don't have the console with the outlet (I don't), there should be a connector under the carpet (center of front seat area below where the console would be) for the center console option. I just removed my carpet recently and found it. I haven't tested for constant power but I assume that harness is for the console option which would include a constant power wire. The reason I mention it is it would save one from having to run new wire if you wanted to install another outlet.
Quick Reply: power outlets....
