Pulling The Heads
Old Jul 25, 2010 | 01:07 PM
  #82
Moneyman19's Avatar
Moneyman19
Originally Posted by lghtngblt02
Since we are talking about the Vs and Is, dont forget about the Flatheads, Ws, Us, Hs, VRs, and or Rotaries... did I miss any?
mmm friend of mine has a rotary engine that we might make into a tractor for pulling
Originally Posted by Blown287
Its been fun so far. I made this procedure for pulling the heads with the timing chains still in place. All the pubs and experts say the chains have to come out, but I thought up a way to pull them with the chains in place, lol.
That 3rd cylinder is the point of fail for the headgasket. I shop-vacced about 8 oz of coolant out of it, lol.
from what i heard there was coolant on my number 6 .. and its warped? so they gotta fix that and now they gotta wrok on a valve tap? im guessing from all the coolant mixing in with the oil? i swear they better give it an oil flush...or more ****s gonna happen.
mmm only if i was out there and had more money.. mmmm wonder if i should join... i'll go in as an officer hahahaha
Old Jul 26, 2010 | 12:46 AM
  #83
Blown287's Avatar
Blown287
Its very possible to warp a head. From what I'm reading your not doing the work yourself? If you are, turn the heads upside down and take a flat surface and put it along the heads. If there is enough room to slide a credit card under you have a warped head. Valve tick can be alot of things. Worn springs, improper lash adjustment, etc.
Old Jul 26, 2010 | 10:26 AM
  #85
trucky's Avatar
trucky
Can I be your pal?! HUH?!
Old Jul 26, 2010 | 03:47 PM
  #86
Blown287's Avatar
Blown287
LMAO
Old Jul 26, 2010 | 03:49 PM
  #87
trucky's Avatar
trucky
Roflcopter
Old Jul 26, 2010 | 11:24 PM
  #88
Dakkkota's Avatar
Dakkkota
Default hey blown
what psi you want tu push? what size of injectors you run, what fuel pump, what pressure you run in fuel rail and what tune will you use? are you using FMU?
Old Jul 27, 2010 | 12:00 AM
  #89
Blown287's Avatar
Blown287
I've been pushing 12-14 psi
Running Ford SVT #39 Injectors
what fuel pump,
Stock
SCT boost/224 Cam tuning.
are you using FMU?
Only for the alcohol injection
Dakkkota, I've pushed more HP and more mods than any other G3 Dakota 4.7L on the planet. If you need advice please don't hesitate to ask.
My complete performance mod list.
Paxton Novi 1000 Supercharger
ASP 3.25" Blower Drive Pulley
Alcohol Injection
Split Second Controller
Functional R/T hood/scoop
KRC 224 Blower Grind Cams
Edge 3000 Stall
SPAL Controller
HHR E-fan
JBA Headers
Spintech Cats
Borla True Dual 2.5" Exhaust
SRT4 2-Bar MAP
SVT #39 Injectors
AEM A/F Wideband
Phantom Boost gauge
Solid Tranny Mounts
Torque Dampers
4.10 Gears
SCT Tuned by Hemifever
Dayco Belt Tensioner
Goodyear Gatorback blower & serpentine belts
180 Thermostat
Old Jul 27, 2010 | 12:18 AM
  #90
sleds's Avatar
sleds
Alcohol Injection
Edge 3000 Stall
SPAL Controller
Proform E-fan
JBA Headers
Spintech Cats
SRT4 2-Bar MAP
SVT #39 Injectors
AEM A/F Wideband
Phantom Boost gauge
Solid Tranny Mounts
Torque Dampers
4.10 Gears
180 Thermostat
Blown, you're going to have to update that copy and paste to include your new e-fan, or did you put the Proform back on?
This has been an interesting read, how's the head gasket coming along?
