upper control arm ball joint???
Old Jan 26, 2011 | 05:34 PM
Dakkkota's Avatar
Dakkkota
Default upper control arm ball joint???
can we have them seperately???
Old Jan 26, 2011 | 05:36 PM
Eimer123's Avatar
Eimer123
Yes you can, but they are easier to change them with them in the arm already.
Old Jan 26, 2011 | 05:57 PM
Dakkkota's Avatar
Dakkkota
if you have a brand and part number feel free to give it to me...i called 4 different auto parts and they are only listed for complete assy 115$ch poor quality
194$ each Moog warranty for life...
Old Jan 26, 2011 | 06:18 PM
rengnath's Avatar
rengnath
If you dont have a ball joint press you may be better off just buying the assembly. 3 bolts and it comes off. Replacing just the ball joint requires more work.
Old Jan 26, 2011 | 06:45 PM
Dakkkota's Avatar
Dakkkota
Default i do have access to a press
and i will not pay 400$ for balljoints!!!!
Old Jan 27, 2011 | 03:36 AM
Desert_Rat's Avatar
Desert_Rat
The lifetime warranty on the Moog's makes the $400 a little better...but only a little :/
Old Jan 27, 2011 | 07:16 AM
Eimer123's Avatar
Eimer123
Ok I failed at this one, I could have sworn I recall someone replacing just the ball on the uppers, but even the manual says its a single unit with the arm and ball.
Old Jan 27, 2011 | 04:06 PM
FrenicX's Avatar
FrenicX
Not even any cheap chinese crap on ebay for anything newer than '04. I rue the day when I have to do balljoints again though. Not fun on an '03 s10.
Old Jan 27, 2011 | 04:12 PM
dakota_raven's Avatar
dakota_raven
Did you check rockauto.com? They got great prices, i have ordered from them before and no complaints.....
rengnath's Avatar
rengnath
Id just buy the assembly from Oreillys and forget about trying to be cheap. Ball joints are a normal wear item.
$97.99 for a Master Pro with limited lifetime warranty
$157.99 for a Moog with limited lifetime warranty and bushings
