question - converting from open to limited slip diff
Old Feb 12, 2011 | 03:24 AM
Q-TIP's Avatar
Q-TIP
Default question - converting from open to limited slip diff
I am looking to convert my open diff to a limited slip. There are a few limited slip options made for the Chrysler 9.25" axle and I don't know if these will work for my truck (2009 Dak with the 9.25 diff).
Anyone else done this? What all needs to be changed if I use the OEM no-slip diff?
Old Feb 12, 2011 | 06:58 AM
projektdirtfab's Avatar
projektdirtfab
not sure but i think the whole 3rd member needs to be replaced.
Old Feb 12, 2011 | 08:13 AM
Eimer123's Avatar
Eimer123
I would read through this
https://dodgeforum.com/forum/3rd-gen...t-project.html
Old Feb 12, 2011 | 10:27 AM
Blown287's Avatar
Blown287
And LSD that is made for a Chrysler 9.25 rear with 31 spline will work. I would go with the Auburn LSD over the stock OEM as the stock LSD has a tendency to grenade the "C" clip. If you search you will find dozens of threads on it. Both Ericemery and I have broke our "C" clips in our stock LSDs.
Old Feb 12, 2011 | 06:58 PM
Q-TIP's Avatar
Q-TIP
Will I need to change my ring and pinion gears if I go with the Auburn?
Old Feb 12, 2011 | 08:31 PM
Blown287's Avatar
Blown287
Not unless you want a different gear ratio. Whatever gears you have now will work fine as long as the LSD is a 9.25 with 31 spline.
Old Feb 12, 2011 | 09:31 PM
thunder98110's Avatar
thunder98110
damn do i have to worry about that^?
Old Feb 12, 2011 | 09:55 PM
Blown287's Avatar
Blown287
If you have the stock Mopar LSD aka "Trak-Lok" then yes, the "C" clips are notorious for grenading. If you search you will find tons of threads on it.
Old Feb 13, 2011 | 01:46 AM
lmrjason's Avatar
lmrjason
what is the difficulty level of installing one of these by yourself?
