Turbo Talk
I just had an idea, not sure if it's a good one or if it's been thought of yet but has anyone ever though of making finned tubing for the return tube so you don't need an intercooler? I could only find some crappy examples online, but you should be able to get the idea. it would take a lot of small welding and I dunno how well the tube you guys use would stand up to it, but here's the pics.
One can compensate for the removal of an intercooler by changing fuel type though.
If you go with a rear mounted turbo likke Remme or myself then you dont need an intercooler. Of course for any boost pressure over 15# i would probably install an ic.
There is also alcohol injection
Certainly under the hood is a no go, short distance and engine heat, but I was thinking that in a remote turbo setup (since they say the distance itself cools the air) adding tubeing that has heatsinking abilities could only add to that effect. just a thought. of course an intercooler that has much better surface area would do a better job, as well as the other accepted methods.
it seems to me like that would be a good concept if your only concern is keeping the exterior of the pipe cool.
I just don't see how it could do much for the air moving inside, unless you had fins inside the pipe itself...but then you would end up with a long cylindrical intercooler, lol
besides, why wouldn't you want to install an intercooler, I think they look sick, I got one installed even though I'm not even at a boost level that requires it yet =D
You are absolutely right, it does look badass. I can't wait to see your rig fully tuned and in action
Well the day couldn't be nicer so i decided to do the intake routing I've been putting off.
Former setup:
New setup:
The materials:
the pictures are hard to see, kinda hard to move around under the truck
Former setup:
New setup:
The materials:
