Hemi Swap 1yr Plan
Old Mar 26, 2012 | 02:28 AM
  #71
FrenicX's Avatar
FrenicX
thanks Steve, yea I picked up an industrial sized tube of engine assembly lube, and have all my timing stuff hammered out. It's really easy, I mean I would prefer to do this 50x before I'd replace lower control arms again...
The general consensus is that you need a special ($130 kinda special) tool to replace the valve springs on a hemi because of those dampers around the spring.
I just rented a regular valve spring compressor from Checker and ground the fingers down to almost nothing, first 2 springs took 2 hours to figure out and get a method down.. and the other 14 took 2 more hours, each cylinder I worked on I kept at TDC so if the valve dropped they wouldn't go far. I also made a tool to compress the cylinders to keep the valves up during the spring compressing moments.
I enjoyed it, and I am glad the cam will be here tomorrow so I can work on it some more.
Old Mar 26, 2012 | 11:16 AM
  #72
06Dak4.7Silver's Avatar
06Dak4.7Silver
Valve springs are always an adventure..I was just doing them on a BMW N52 engine but it actually wasn't too bad. The hardest part is getting the valve keepers to lock in place, not compressing the spring itself. I would love to do all this to a Hemi though..glad you are having fun and learning
Old Mar 26, 2012 | 07:54 PM
  #73
FrenicX's Avatar
FrenicX
Got a couple good things today, and installled one of them.
There's a sale on the fan at Amazon by the way, $32 and the derale controller is $45, all new. So $80 total could have you an e-fan.
And the cam getting installed.
Old Mar 26, 2012 | 08:36 PM
  #74
slicktrick's Avatar
slicktrick
man, i just did that fan/derale, hate it when i miss out on a deal.
just missed out on the monroe rebate by 2 freakin' days too early as well......go figure
you get the details all figured out with this swap & next you'll be selling hemi/dak conversion kits on amazon & ebay
Old Mar 26, 2012 | 08:47 PM
  #75
06Dak4.7Silver
You got links, Preston? I would love to pick up a fan
Old Mar 26, 2012 | 09:44 PM
  #76
FrenicX's Avatar
FrenicX
I missed the fan deal, but not the controller deal luckily. But that happens to me ALL the time haha.
And yea, I would love to make kits. What I want is some mounts that use the factory frame mounts so it can be a plug-n play drop-in. I have an amazing welder who will be helping me on swap day so hopefully I can get something hammered out then.
Here's the one for the fan (hurry, it says 2 left)
http://www.amazon.com/TYC-621450-Che...2811829&sr=8-2
and here's the controller with a threaded temp sensor, and a push in sensor.. respectively
http://www.amazon.com/Derale-16749-A...2812191&sr=1-1
http://www.amazon.com/Derale-16759-A...2812191&sr=1-3
Old Mar 27, 2012 | 01:39 PM
  #77
mikeg87xx's Avatar
mikeg87xx
I have an 06 Dak w/ the HO engine... would I benefit with a Hemi Swap, or should I just keep building up my HO? I was just about to order my new headers then saw this thread...
Old Mar 27, 2012 | 04:54 PM
  #78
MitsuRaider's Avatar
MitsuRaider
In the long run, the Hemi will always have more potential for HP, but it will be along time and a lot of $$$ before this is the case.
The HO has forged internals, which make it a dream set-up for a turbo set-up.
But if you do decide to go with the Hemi, please let me vulture your HO engine?
Old Mar 27, 2012 | 06:40 PM
  #79
thunder98110's Avatar
thunder98110
i would rather have a boosted HO running 20# than a hemi.
Old Mar 27, 2012 | 06:59 PM
  #80
MitsuRaider
yeah, but I rather have a Hemi boosting 15lbs
