06 slt 4.7 towing
Old 06-14-2018, 09:23 PM
Stan Ding's Avatar
Stan Ding
Stan Ding is offline
Default 06 slt 4.7 towing
Hey all. Just looking for some input. I bought a parts truck a little over 2 hours away and I need to get it home. My original plan was to rent a u haul car trailer and tow it home but u haul won't rent the trailer to me stating the load is larger than what the truck is rated for. Anyone towed a dakota with their dakota? Thinking about telling u haul I'm hauling a car.
Old 06-15-2018, 01:41 AM
19dhyer's Avatar
19dhyer
19dhyer is offline
yeah you could tow another dakota with no problem. My personal Dakota has the Heavy Duty and Towing package and is rated to tow nearly 9,000 pounds so I think youre fine even without the extra stuff
Old 06-15-2018, 07:27 AM
jkeaton is offline
Dodge Forum Administrator
Door sticker lists your max towing weight.The max towing capacity is 7150 lbs. properly equipped. Not sure where you get 9000 lbs from. Can you tow more? Probably, but as you see, you can't do it legally. And if you get into an accident towing over capacity, good luck with your insurance.
https://dodgeforum.com/forum/3rd-gen...-equipped.html
Old 06-17-2018, 12:22 AM
19dhyer's Avatar
19dhyer
19dhyer is offline
max ive seen someone towing with this truck safely was 9,000 pounds
Old 06-17-2018, 07:48 AM
jkeaton is offline
Like I said, it can probably be done but If it’s over the towing limit, it’s not “safely”.
Old 06-17-2018, 08:46 AM
superdak05's Avatar
superdak05
superdak05 is offline
towing isn't the issue, you can tow a house if you want, stopping is the issue, I towed 3 tons of wood pellets with my ****box with ease, only issue was backing up. not much traction, but once moving it was fine, just remember keep truck in tow/haul mode, don't let it get into overdrive, that's when tranny issues happen and if you have the factory cooler for tranny that's a plus.
Old 07-24-2018, 01:21 PM
Dodgevity's Avatar
Dodgevity
Dodgevity is offline
If towing a car any decent distance, I would put it on a 4 wheel trailer with brakes on it. The Dakotas with tow pkg have a trailer brake controller connection up under the dash and the controller is about 50 bucks from your local parts store. Point is, the trailer brakes along with your truck.
Old 07-28-2018, 09:00 AM
HeyYou is offline
Received 3,189 Likes on 2,942 Posts
Ok, you have a 4.7L engine, what trans? Cab configuration? 2 or 4 wheel drive? Does it have a tow package?
Quick Reply: 06 slt 4.7 towing
