3rd Gen Durango 2011+ models
IPod and Mediacenter 430?
Old 08-10-2011, 12:19 PM
xsdbs's Avatar
xsdbs
xsdbs is offline
email sent, let me know how it goes, ok.
Originally Posted by cbrrider012
I rechecked the web and it says .upd so that should be correct that it downloaded it that way... PM sent
  #52
Old 08-11-2011, 07:29 AM
cbrrider012's Avatar
cbrrider012
cbrrider012 is offline
DId this update last night and it worked well... Had some issues with the one on the guys hosting page but xsdbs helped me and sent me another update and it worked easily... Now I can play my iphone through ANY method flawlessly! Thanks xsdbs for the help!
  #53
Old 08-11-2011, 09:39 PM
xsdbs's Avatar
xsdbs
xsdbs is offline
cbrrider012,
You are welcome, sorry that you went thru some headaches but I'm glad that we were able to work together and got it going.
  #54
Old 09-11-2011, 02:20 AM
provoking's Avatar
provoking
provoking is offline
Originally Posted by gamoon
I have a XOOM and used the bluetooth connect option and it worked great. Can control what music plays from the XOOM or console the only issue is the console does not seem to display the song titles, artist, etc.
I have a Xoom and an RBZ, but have no idea of how to connect via bluetooth. Can you give me some guidance? Thanks!!!
  #55
Old 09-12-2011, 08:24 PM
xsdbs's Avatar
xsdbs
xsdbs is offline
WELL HERE WE GO AGAIN:::::::: if you have an ipod or iphone,
please do not do the 4.3.5 update till i can test it. I have just been told by a person that I have helped with the Uconnect update that there is a new problem with this update. I will be testing it and let you know more soon.
  #56
Old 09-12-2011, 08:27 PM
xsdbs's Avatar
xsdbs
xsdbs is offline
This should be the same as pairing a phone, then in order to play it, press the media button, select AUX, on the screen there will be a soft key that says DEVICES, touch that softkey then a menu will appear, select the xoom and start playback.
  #57
Old 09-12-2011, 08:36 PM
NY-Durango's Avatar
NY-Durango
NY-Durango is offline
I just applied the update and it worked perfectly. I have had the truck since June and the iphone 4 never worked correctly. It now plays great thru my system. Thanks to all the guys on this board who posted the update.
  #58
Old 09-13-2011, 02:01 PM
Leman's Avatar
Leman
Leman is offline
I also have a problem with the iPhone 4. Can somebody please help a Swiss bloke download the update..... Cheers in advance.
Also my unitmseems to reset the clock occasionally without prompting....
  #59
Old 09-13-2011, 04:29 PM
Robert Calhoun's Avatar
Robert Calhoun
Robert Calhoun is offline
I would check the the IOD Main Fuse. It has a white sleeve around it in the fuse box. Make sure it is tight. Matter of a fact, check all your fuses.
  #60
Old 09-14-2011, 12:23 PM
xsdbs's Avatar
xsdbs
xsdbs is offline
Hello, can you tell me the problems you are having with the iPhone4 and I will try to help you out.
Quick Reply: IPod and Mediacenter 430?
