3rd Gen Durango 2011+ models
Make your durango more peepy
Old Dec 21, 2011 | 01:00 PM
  #31
switchblade906's Avatar
switchblade906
Sorry but I disagree. I've built race cars, raced race cars, and built cars just to the limits of being street legal. It is possible to make it worse but if you know what your doing and do your research on what parts go with others the best then you can always make something better. But sure if you just through any old exhaust and intake on there you it's not gonna be as good as factory.
Old Dec 21, 2011 | 01:05 PM
  #32
deedubb's Avatar
deedubb
Originally Posted by JRRF
Doesn't the CTS-V (which is already blown, and is arguably one of the fastest 4 doors ever produced) only have 556hp?
Sorry, i should have clarified, my ctsv was an 05, naturally aspirated in stock form at 400hp. I did a lot of work to get 200 more hp
Old Dec 21, 2011 | 03:36 PM
  #33
sbmG8GT's Avatar
sbmG8GT
Not true at all, it is very easy to get 100+ hp out of the new CTS-V. There are numerous shops with 700+hp options that are really only a pulley, exhaust and tune away. If anything I would say the CTS-V is slightly de-tuned as it has a similar setup to the ZR-1 which has almost 100hp more.
You can always do something. But considering that the CTS-V is already a very pumped up version of the CTS, and a well balanced one at that, if you did much to it you might get a few more hp, but you'd likely also mess things up pretty good and destroy the overall feel and driveability of the car. And you could also actually lose hp if what you did didn't coordinate well with the rest of the car. What I'm saying is that the CTS-V is already a pretty ultimate machine (Ferrari has even co-opted its braking system). It gets to 60 in nearly 4 sec. It would be very difficult to make it better without very possibly making it worse.
Old Dec 21, 2011 | 04:35 PM
  #34
switchblade906
^^ pretty much exactly what i said in the first place.....
Old Dec 22, 2011 | 08:10 AM
  #35
JRRF's Avatar
JRRF
You can add hp almost indefinitely (heck, you can create a CTSV top fueler if you really wanted to). But manufacturers (even of very high performance cars) don't beyond a certain point because they want to create not only a balanced car, but also one they can warrant. You can do lots of things to void your warranty, but you will likely then need your warranty when you don't have it after you blow something that couldn't handle the stress.
It's like inflating a balloon. If you have a balloon that's half full (some run of the mill car), you have lots of room to keep blowing it up. If you have a balloon that's near it's limit (a CTSV, E63, etc.) you can keep blowing and make the balloon larger, but the risk of it popping goes up exponentially. The concept behind any production road car is that you can drive it every day and not have to think about winding up on the side of the road. If you're only interested in a track machine (like the potential top fueler I mentioned) then sure, the sky's the limit, and you won't mind replacing parts after every session.
Old Dec 22, 2011 | 10:06 AM
  #36
edfiero's Avatar
edfiero
Can we get this thread back on track. I'm not interested in the CTS-V, I want to know if a single press of the throttle is really changing anything. This to me sounds like the same snake oil that says if you old your keyfob up to your chin then remote start will have greater range.
Can anyone point to something in the factory service manual that says a press of the throttle as described by the OP resets anything or engages some sort of enhanced throttle settings???
Old Dec 22, 2011 | 04:56 PM
  #37
boosted20v's Avatar
boosted20v
can't point to anything but the old remote on the chin thing does work! FWIW I did the gas pedal thing and I thought it worked.
Old Dec 22, 2011 | 05:02 PM
  #38
switchblade906
I thought it worked too but i can't be absolutely sure since i don't have a dyno....
Old Dec 24, 2011 | 11:14 AM
  #39
Leman's Avatar
Leman
Strange, that sounds a lot like the reset procedure for the DIC oil change warning. (Three times for that) Must reset something or other.
There seem to be quite a few "easter eggs" in this cars internals :-)
BTW the remote start with the key fob against your head does, to my great surprise work, for door unlocking but not for remote start... duh. must have a metal bit in my head somewhere....
Old Dec 24, 2011 | 06:10 PM
  #40
Jose Luis Ramirez's Avatar
Jose Luis Ramirez
yes it does work especially when you go to a bigger throttle body assembly
