3rd Gen Durango 2011+ models
Make your durango more peepy
Old Feb 4, 2013 | 07:18 PM
  #61
CMil527's Avatar
CMil527
Lol what throttle trick? What I miss?
Old Feb 4, 2013 | 08:11 PM
  #62
SS2RT's Avatar
SS2RT
ha knew that would get your attention !!
i just named it that but its the "recalibration"
or whatever that happens when you turn the key
on, wait a bit, slowly press gas pedal to floor, slowly
let it back up, and shut car off
I swear my ride was ALOT more "peepy" haha today
try it if you didnt yet it really did wake my
truck up from the doldrums..
Old Feb 4, 2013 | 08:46 PM
  #63
DJ Hellfire's Avatar
DJ Hellfire
Originally Posted by shelbymopar89
This kinda sounds like the PCM reset on the older Rams. The explanition for the trucks was that the truck would "learn" how you drove and adjust the gas pedal/tranny shift points to fit how hard you drove. When you do this it resets it to factory settings, if you always drove the pee out of it, you would not notice a difference. If you baby it a lot and then do it, you might notice more of a difference. FWIW
This is exactly the case here. This "trick" works on most modern computer controlled vehicles. It's called adaptation values. You're just resetting them and making the car relearn your driving habits. Then the computer will adjust accordingly! This trick is useless because the settings get relearned in a few trips. Unless of course you plan to drive like an animal every where you go after doing the reset, or unless you're gonna be doing this reset every other day!! Waste of time, except maybe at the track!
Old Feb 26, 2013 | 09:14 PM
  #64
FSTDANGO3's Avatar
FSTDANGO3
I did this on my wifes Avenger RT back in 2009. It definetely responded better because it learned our driving habits. I will more than likely do this on my new D since it cant really hurt.
STEVE
Old Feb 26, 2013 | 11:00 PM
  #65
CMil527's Avatar
CMil527
I've never tried it, gotta give it a try.
Old Feb 27, 2013 | 10:18 PM
  #66
wi-steve's Avatar
wi-steve
I tried it on my V6 Crew. I think it did make a difference. Or could be placebo effect. Who knows.
Steve
