3rd Gen Durango 2011+ models
Another issue with my 2012 Durango - Remote Start
Old Nov 8, 2012 | 11:54 PM
  #111
Frohoss's Avatar
Frohoss
Just had my D's remote start flashed today. Didn't have time to test it until now. Not happy with the results. Heat/AC still doesn't work after you remote start it until you open the door. Now what?
Old Nov 9, 2012 | 07:07 AM
  #112
bbtkd's Avatar
bbtkd
What was the outside temperature? If it was between 40 and 70, then it won't preheat/precool.
Old Nov 9, 2012 | 01:09 PM
  #113
Jazi's Avatar
Jazi
Could it be that the dealer didn't apply the correct update? As its hard to believe that they spent all this time working on an update and then it doesn't work in the end.
Old Nov 9, 2012 | 02:11 PM
  #114
sdquattro's Avatar
sdquattro
I noticed that in my 2013 Crew, the AC will maintain the setttings prior ro shutting off the D, however if I leave it over night or for an extended period of time, maybe even a few hours or so, the AC will not be on upon remote start. Haven't tried it with the heater though!
Old Nov 9, 2012 | 03:00 PM
  #115
Frohoss's Avatar
Frohoss
When I tested both the heater and ac by remote start it was about 35 degrees. Neither worked.
I took it back to the dealer this morning and they confirmed the update was flashed correctly. They also re-flashed it with no success on the remote start issue. They verified that it was not working correctly. They went out to their lot and tested on another identical D and that one failed as well. They told me they were waiting for an answer back from Chrysler. Made appointment for next monday to dig deeper.
I do have a question for all 2011-2013 D owners with the remote start feature...
Does anyone have a working remote start that functions properly? (as as common sense tells how it should work) I.E. when you remote start it does the heat/ac/heated seats/defrost ect. turn on immediately without having to open your doors regardless the external temperature?
Old Nov 10, 2012 | 09:04 AM
  #116
coldsteel's Avatar
coldsteel
My 2011 Citadel worked flawlessly from Day 1 (March 12, 2011).
Old Nov 26, 2012 | 08:34 AM
  #117
funatic's Avatar
funatic
It finally dropped into the mid 30's this past weekend and I able to test the remote start again. Happily the driver heated seat turned on both times, and the car was warm. I guess the dealer flash did work. yay!
Old Nov 26, 2012 | 10:10 AM
  #118
coldsteel's Avatar
coldsteel
That's great to hear. One bit of advice if you don't want to climb into a vehicle that you expect to be warm and freeze your 'tookus': If the temperature is hovering around the temp. activation mark and your front-end is facing the sun, the sensor will warm above the outside air temp and will not activate when you remote start.
Try and park facing away from the path of the sun and the sensor will remain at the ambient air temp. and will function correctly.
Old Nov 26, 2012 | 10:46 AM
  #119
Frohoss's Avatar
Frohoss
It's been in the 20's here the last few nights. I have a 2012 Crew leather. My heated driver seat comes on too when I remote start it. Also my rear defrost comes on for some reason.(no frost) Those are the only 2 options that are being engaged. No hot air blowing etc...
Is the hot air supposed to blow out of the vents when remote started? Mine will only come on after I open the door. Are we able to enable the passenger heated seat too when it's remote started?
Chrysler/Dodge tells me my D Crew will not blow hot/cold air when remote started because "that's the way it's designed"
I'm confused by this because other D owners have said their remote start works flawlessly (engages heat/ac immediately after it's remote started) while others say it doesn't engage any heat/av or it only engages the driver heated seats.
I'm so frustrated with the supposed "design" of the D's remote start system. It's unlike any other 'normal' remote start on any other vehicle. IMO it's pointless if it won't engage the heat/ac immediately.
Don't take this as me crying but rather trying to get to the bottom of why my remote start doesn't function as other remote starts do.
Old Nov 26, 2012 | 12:24 PM
  #120
funatic's Avatar
funatic
I haven't noticed warm air blowing from the vents, but it does appear to blow on low from the defroster and floor. The vents do not turn on until I open the door.
