View Poll Results: What oil is in your engine?
Mobil 1
251
32.51%
Royal Purple
123
15.93%
Amsoil
57
7.38%
Valvoline Full Synthetic
86
11.14%
Pennzoil Synthetic
36
4.66%
Castrol Synthetic
65
8.42%
Quaker State 4x4
17
2.20%
Havoline Synthetic
2
0.26%
Other Full Synthetic
29
3.76%
Whatever the Dealership sticks in
28
3.63%
Synthetic Blend (specify in a post)
20
2.59%
Conventional (dino) oil (specify in a post)
58
7.51%
Voters: 772. You may not vote on this poll
Motor Oil
Old Sep 27, 2011 | 12:00 AM
  #111
BMCTMD's Avatar
BMCTMD
Mobil oil, Mobil filter, Synthetic winter, Dino summer!
Old Sep 27, 2011 | 02:08 AM
  #112
shrimp_2's Avatar
shrimp_2
quick question.. in may bought an 06 with a hemi has 53k miles and time for an oil change and was wondering if it'll hurt the engine to switch to synthetic oil if it has only seen regular oil. does that make sense? is synthetic oil needed/worth it; all stock except for a 3865 super chip.
Old Sep 27, 2011 | 12:12 PM
  #113
Lowrider82's Avatar
Lowrider82
As long as the viscosity is the same, no. So if you use 5-20 regular oil the synthetic will be the same as long as you use the same weight. Only difference is how there made and from what. Sythetic being the better of the two
Old Sep 27, 2011 | 09:11 PM
  #114
shrimp_2's Avatar
shrimp_2
so yes it wouldn't hurt to run synthetic if it's never been used? thanks. and yeah i saw in the manual that 5w20 is needed.
Old Sep 28, 2011 | 12:34 PM
  #115
Lowrider82's Avatar
Lowrider82
Simple answer yes its fine to use no matter on how many miles you have on it. The vescosity is the same so it's not going to leak if that's what you have heard. It's the same thickness. Only difference is that synthetic lubes a hell a lot better
Old Oct 3, 2011 | 12:46 AM
  #116
Manvin's Avatar
Manvin
I would never run synthetic if your truck leaks. Synthetic oil is made of smaller molecules or whatever. Its ment to help the oil get to the top of the engine faster to limit the amout of metal on metal contact. but if the truck does not leak oil it doesnt matter if you switch between the two. just make sure you run 5W20.
Old Oct 6, 2011 | 12:35 AM
  #117
iacordero's Avatar
iacordero
Castrol GTX conventional 10W-30 with Fram ToughGuard filter.
I have a couple of questions, though:
1. I see that a lot of people don't seem to like Fram filters. I realize that all of this is personal preference, but is there a legitimate reason to avoid Fram? I always thought they were a pretty reputable brand.
2. I have a lot of sludge, and thought that doing a couple of changes at around 1K miles in addition to a cleaner such as MMO or Seafoam would help flush the junk out (which is why I decided to go with the cheaper conventional oil and save some $$$ until I can get it somewhat clean and then maybe switch to synthetic). Would this help speed up the process?
3. This one is more rhetorical than anything else... Unless I'm severely misinformed, how on earth is it that a 5.9L engine only takes 5qts???
Old Oct 6, 2011 | 12:54 AM
  #118
iacordero's Avatar
iacordero
Through the magic of YouTube, I have answered my own first question. Kind of scary how terribly made the Fram is... I don't believe I will be purchasing another one of those any time soon. Just goes to show that not all filters are made alike. But if you guys could answer my other questions, it would be greatly appreciated.
Old Dec 10, 2011 | 02:28 PM
  #119
MD87's Avatar
MD87
im running mobil 1 oil with a mopar filter and change it every 3k, but im about to change to royal purple with my next oil change
Old Dec 12, 2011 | 12:15 AM
  #120
me0418840987's Avatar
me0418840987
Originally Posted by stuntpilot
Mobil 1 10w30 stock Mopar filter every 5k! Factory 3k oil changes are a waste of the worlds natural resources and a Dealer scam!
They may be, but my mother got free oil changes for as long as she owns the 2006 Caravan that she bought USED. Any dealer scam that's free is good in my book, It gets it every 3000. Has 198,000mi on it now, and have only done a ps pump on it. Do have to check underneith occasionally, and grease steering components, but with a conventional oil change now costing about $22 done myself, Ill let them do it, since she drives by there everyday anyways.
Anyway, I run Shell rotella 5-40 syn in everything but the neon, that gets 5-30 valvoline Syn all are changed every 5,000. Neon-250,700mi Ram1500-172,000mi.
