Superchips Questions and Updates
Old Sep 2, 2009 | 12:00 AM
  #1131
davb673's Avatar
davb673
I was reading a thread about tranny swaps over on the hemitruckclub site, and there is a way to swap some pieces and convert an 03 to 04 config...
Old Sep 2, 2009 | 12:30 AM
  #1132
OklaHemi's Avatar
OklaHemi
forgive me for not chosing to read through 114 pages of post but is the tranny tunig for the flash pac or the cortex
Old Sep 2, 2009 | 02:14 AM
  #1133
06 Ram5.7's Avatar
06 Ram5.7
Originally Posted by ThunderedRod
This is a bit off topic but it is the place for superchip questions. I called superchip today to ask about any problems i might have with my TTi long tube headers and y-pipes that i am installing. They said the long tubes will create a lean condition. Will i be okay? Should i not run the tune? Should I install a air-fuel gauge and keep an eye on it? I really want to be able to use the tuner with the headers.
Originally Posted by Off_Road_Teacher
From what I have read (I don't have an A/F gauge so I don't know for sure) the SC 91 tune already leans out the mix a little. So adding some LT's will probably lean it out even more. How lean will it get, I don't know. You will have to install an A/F gauge to find out.
I had a question about the A/F mixture. If the Superchips leans out the mix, and putting LT's on leans it out even more, would using 93 octane help at all? I'm just wondering, since the performance tune is for 91 octane, but most gas stations around here don't have 91, so I use 93 octane.
Old Sep 2, 2009 | 12:24 PM
  #1134
SilsHemi's Avatar
SilsHemi
For the 3865 (2nd gen Flashpaq) and the Cortex 3950.
Sil
Old Sep 2, 2009 | 04:40 PM
  #1135
joe44473's Avatar
joe44473
will the new tranny options be developed later if not can I ask y we are being screwed. thanks
Old Sep 2, 2009 | 06:08 PM
  #1136
SilsHemi's Avatar
SilsHemi
Joe,
03 expanded support is lacking across the board. It's just not Superchips. The PCM/TCM are different and more difficult to deal with in that application. I know that's not what you want to read, but it's true.
I can't be sure Superchips will go back to 03. Just keep asking for additional 03 support. It doesn't hurt.
Sil
Old Sep 2, 2009 | 08:09 PM
  #1137
Invigor's Avatar
Invigor
How do I log 1/4 mile and 0-60 times on my cortex?
Old Sep 3, 2009 | 10:30 AM
  #1138
SilsHemi's Avatar
SilsHemi
Link to DAQ2 PDF for the Flashpaq, but basically same concept.
Make sure you update to Advance Data Aquisition, so you can have all the logging goodies.
http://app.flashpaq.com/support/manuals/DAQII/DAQ2.pdf
Sil
Old Sep 4, 2009 | 06:41 AM
  #1139
ttam7777's Avatar
ttam7777
I got my SC3865 yesterday and got it installed. I had a question regarding the Tow Tune. Do you have to turn on the Tow/Haul Mode while your using it?
What tune are you guys using most and what advanced settings are you using? I'd like to get the most out of my programmer, but I don't really know my way around the settings and don't know what and what not to mess with. Thanks.
Old Sep 4, 2009 | 12:37 PM
  #1140
SilsHemi's Avatar
SilsHemi
Nope, unless you need to for actual towing.
I use 91.
The settings you'll most probably use in advance tuning are, REV LIMIT, SPEED LIMIT, WOT SHIFTS 1-2, 2-3 and MDS DISABLE. I would disable MDS. Nice gains in power disabling MDS here. The truck just drives better without it. You can incrementally change your other settings until you find your sweet spot.
Sil
