Superchips Questions and Updates
Old Jun 3, 2009 | 12:44 AM
  #621
Jason D's Avatar
Jason D
Originally Posted by ArkHemi
Question about updating my tuner. I have the 3815 and am currently running the 91 tune. If I want to update the tuner do I need to set my truck back to stock BEFORE I update? In other words, will my tuner lose my stock tune if I update it?
No you can update the tuner without going back to stock on the truck with no issues.
Old Jun 3, 2009 | 01:04 AM
  #622
RedTruck-VA's Avatar
RedTruck-VA
Default 03 Ram tune
Originally Posted by joe44473
Im sure the answer to my question is on here somewhere but its so full of info there are 62 pages so i was wonderin if someone could tell me what is the best programmer for my 03 Dodge ram 1500 5.7L Hemi with dual flowmaster exhaust and k&n cold air intake. Plz help thanks all!
Joe,
Seems like we have similar vices. I also have a 03 Ram 1500 5.7, K&N CAI and flowmaster dual exhaust and I'm using the SC3865 91 octane advance tune. This has been the best spent money yet. It has really waken the truck up and the mileage has also improved. I'm running 285/50-20 (30.5") tires and the only down side is I can't get it out of the hole without a lot of wheel spin. Next mod will be a 3:92 gear with posi. The truck is serious fun.
Old Jun 3, 2009 | 01:46 AM
  #623
06 Ram5.7's Avatar
06 Ram5.7
Originally Posted by Jason D
Ok so it sounds like a few more of the updating bugs have been worked out so i went ahead and updated my cortex today. Well after updating my tuner and then updating the tune in my truck I started going through some of the functions it has.
When I went into the tire sizing function it showed 31.5" tires. My truck came with 33's and I curently have 33's on the truck.
My question is should I have changed it to 33" tire size from the 31.5" that it showed?
My truck is the same way. I have the 275/60R20 (33”) tires, and the Superchips programmer says they are 31.5”. But I would leave it at 31.5”, that’s what it thinks the stock tire size is, so it won’t adjust the speedo. When I got the Flashpaq a couple years ago, I changed the setting to 33”, but when I did, my speedo was about 5 mph fast, so I kept it at 31.5”, and the speedo is perfect. Hopefully, one of the Superchips people can explain why it does this.
Old Jun 3, 2009 | 01:57 AM
  #624
Jason D's Avatar
Jason D
LOL Guess I will have to go change it back. I figured that it has to be smarter than I am so I changed it to what I actually have for tires(33").
Old Jun 3, 2009 | 02:50 AM
  #625
ArkHemi's Avatar
ArkHemi
Jason, thanks for the reply. I'll go ahead and update and see whats new.
Old Jun 3, 2009 | 06:36 AM
  #626
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
might be because of tire wear and because the tires compress a little with the weight of the truck on them. if you want to be really precise, go measure from the center of the wheel to the ground, and multiply by 2 to get what your 'real' tire size is.
Old Jun 3, 2009 | 06:42 AM
  #627
SilsHemi's Avatar
SilsHemi
If the tires are the stock 275/60/20, 31.5" is correct. If you have stock tires, no need to change that setting.
Sil
Old Jun 3, 2009 | 10:42 AM
  #628
Jason D's Avatar
Jason D
Sil
Well i got rid of the 20's and got 285/70/17's which are about the same height.
Old Jun 3, 2009 | 11:12 AM
  #629
Stormin264's Avatar
Stormin264
according to http://www.s-series.org/htm/calc/tiresizeconv.htm
275/60/20's are 33"
Old Jun 3, 2009 | 12:24 PM
  #630
xfeejayx's Avatar
xfeejayx
275/60/20's are 33"
33" is right. the 31.5 are on the 17" rims. again, it might just be because the weight of the truck reduces the radius on the tire. how did you confirm that putting the setting to 33" makes the truck read fast?
