Diablo Information and Reviews
Old Apr 1, 2010 | 06:27 AM
  #591
blue07sport's Avatar
blue07sport
im not sure, but my 07 has it. i looked at it the other day and when i went to adjust it, the middle number already said 255, but the scale only goes from 0-50. so does that mean its all ready set higher than i can manually set it? if i press either arrow it will drop the 255 down to 0-50
Old Apr 1, 2010 | 09:42 AM
  #592
truckin151's Avatar
truckin151
I haven't had a chance to go load the latest CROM so maybe it is in there but I have heard of some of the 05's having it and then the 06 on up having it. Im gonna check over on the DSP site and see if I can find anything later tonight.
As for the adjustment, if it is only 0-50 that you can adjust it it probably means that 0 is where it is now (so 255) and 50 would be +50 on top of that. So basically you can probably adjust it fron 255 to 305 or at least that is what I would assume it would be
Old Apr 2, 2010 | 09:10 AM
  #593
lxman1's Avatar
lxman1
Site Moderator
Mine are at plus 50
Old Apr 5, 2010 | 01:24 PM
  #594
butch1581's Avatar
butch1581
Originally Posted by lxman1
I agree, Tire pressure would not be called line pressure. It's does the same thing as DirtyJohn did on hos 04 with a resistor in the line pressure wiring to the transmission.
I think my transmission shifts a little faster with the tire pressure turned up all of the way
according to Diablo there is no tranny adjustment for line pressure:
http://www.diablosport.com/index.php...wtopic&t=22010
Old Apr 10, 2010 | 01:01 PM
  #595
DODGEtheRAM's Avatar
DODGEtheRAM
Question Need help with 1st install/tune ever?!?!?!?
Dodge Community,
I am having trouble with the first installation of a tune on my Ram. I own a 2007 Ram 1500 Reg Cab 4x4 Sport 2Dr 4x4 5.7V8Hemi.
During the first install to the truck i am receiving the following error after turning engine on (Clearly not starting the truck though). "This Vehicle needs an update. diablosport.com/dcx Calid: 05094405AG.............................
What is this all about? I just updated with the latest crom v.9r07 on the U7137
Customer support isn't open on Sat!
Thanks
Old Apr 10, 2010 | 03:05 PM
  #596
AWE Daniel's Avatar
AWE Daniel
You probably just need to download the calibration update, but I tried the 07 crom myself and could not get it to work, I still have the 06 if you need it
Old Apr 10, 2010 | 03:12 PM
  #597
DODGEtheRAM
AWE D
Where do i get this calibration update? I thought the only updates where the CRoms. Sorry new to the tuning community.
Thanks for the help
JD
Old Apr 10, 2010 | 03:20 PM
  #598
AWE Daniel's Avatar
AWE Daniel
The first time I plugged mine in It told me something like this vehicle needs an update, so on the website where you download the croms there is a program you download, I think its called DSDownloader. Once you hook it all up and install the program it should automatically find the calibration update for you. You probably need the drivers for your cable too.
Did you hook up the tool before you did the 07 update? If you didn't then the tool wouldn't have told the program to find the calibration update.
Old Apr 10, 2010 | 03:33 PM
  #599
DODGEtheRAM
I do have all that setup. But it never mentions any calibration updates. Im connected and the DSD does not recognize that it needs a calibration update. I will just have to wait for Monday it seems.
Thanks
Old Apr 10, 2010 | 03:34 PM
  #600
AWE Daniel's Avatar
AWE Daniel
If you want I can send you the 06 crom, Its no different than the 07, the 07 just fixed a glitch on the 05 and 06 trucks. The 07 for me kept telling my my calid wasnt supported, even though I had the 06 running for months.
