Tug of war. Ram 2500 vs. Siverado 2500
Old 09-04-2011, 09:23 AM
Joe6223's Avatar
Joe6223
Joe6223 is offline
Default Tug of war. Ram 2500 vs. Siverado 2500
Hi i gonna be doing a tug of a war tomorrow and was wondering for tips and who should prob win.......I have a 2004 Ram 2500 hemi it has a Diablo programmer, intake and 35 inch tires. It has limitedslip with 3.73s..........And my buddy has a 2004 siverado 2500 with 6.0 it has a true dual exhaust and hypertech programmer...has 265 tires and a locker with 4.10s
Old 09-04-2011, 09:30 AM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
I think his 2.65's and 4.10's are going to have you buying a transmission.
Best of Luck------I hope you win!!!!!!!!!
I think you'd be more evenly matched if you had a Power Wagon
Old 09-04-2011, 10:58 AM
BadHazard's Avatar
BadHazard
BadHazard is offline
x2 on the above post. He will win. His rear end is better. I wouldnt do it.
Old 09-04-2011, 02:08 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
WAY worse than powerbraking! Nothing good comes of this.
Tug-o-wars are absolutely pointless and here's why....
Forget about power, it's all about traction. Traction has to do with the tire compound and the amount of weight over the axle. If you were to have the same exact tires and same weight over the axle(weighed by a scale) Then and only Then would it be a fair match.
The fact he has a locker means he has 2 tire power where as you will have 1 tire power. EVEN if both tires are spinning there is still traction loss and clutch slippage with an LSD.
Your 3:73's with 35's make your gearing like 3:23's w/stock tires. he'll spank you for torque anyday with 4:10's and stock size tires. Hemi's with 35's are dogs off the line!
4wd...you'll def brake something or fry your trans or transfer case!!!
x3, I wouldn't do it unless you have excess funds to replace broken parts and can handle getting trashed talked the entire time you own your truck! As long as you hang out with that buddy, he'll trash talk on how he beat you. It's just never a good thing.
If you both want to battle, hook-up to compatible trailers and do a run up a hill. That will seperate the two trucks! trucks are meant to pull, not to strqaight out race. I've always done uphill competition when going trailer towing up long hills with buddies.
Old 09-04-2011, 02:13 PM
stewie01's Avatar
stewie01
stewie01 is offline
But if you do it please youtube it!
Old 09-04-2011, 02:53 PM
adventurer's Avatar
adventurer
adventurer is offline
the only thing u can do if u insist doing the tug of war u can reduce the air pressure in ur tires so u can get more traction and warm them up before u start and u can adjust the programmer to 93 octane and pray that nothing will go wrong , good luck waiting to see the result
Old 09-04-2011, 03:11 PM
John  M's Avatar
John M
John  M is offline
It's more about technique than hardware. Hold your brakes at the beginning. The winner in these "matches" is the one whose tires don't spin. When he starts to slip, nail the gas. You'll drag him around like nothing was behind you.
If you both hit the gas at the same time, the winner is the one whose tires hold the longest. None of this is a test of a truck's ability.
Old 09-04-2011, 03:57 PM
BadHazard's Avatar
BadHazard
lol yea post a video if you do it.
Old 09-04-2011, 08:27 PM
Marklorenzo's Avatar
Marklorenzo
Marklorenzo is offline
I never really liked the idea of a tug a war between trucks...too much stress onto truck in a standstill point
Old 09-04-2011, 09:18 PM
xjfever's Avatar
xjfever
xjfever is offline
I wouldn't do it either, but look forward to the video.
Quick Reply: Tug of war. Ram 2500 vs. Siverado 2500
