When STUCK happens...
on
What do you 4x4 guys carry as far as recovery equipment (and 4x2 guys too, for that matter)...
I always have:
Warn winch (M8000)
(2) 6 ton clevis' attached to winch mount
(2) additional 6 ton clevis'
16,000# rated ****** block
30' 30,000# lb. tow strap
8,000# axle strap
4"x10' tree saver
folding shovel
12v jump starter w/ air compressor
MAPP gas welder w/ rods suitable for steel, aluminum welding and brazing
tire repair kit
fire extinquisher
bottle jack, rechargeable Q-Beam, 12v Q-beam, & various flashlights.
and if I happen to have the ATV in the bed then I also have:
Warn 2.5 winch
(2) 1 ton clevis'
7,000# ****** block
15' 10,000# tow strap
axle strap
3"x10' tree saver
portable 12v compressor
tire repair kit
Because STUCK HAPPENS...
I always have:
Warn winch (M8000)
8,000# axle strap
4"x10' tree saver
folding shovel
tire repair kit
fire extinquisher
Warn 2.5 winch
(2) 1 ton clevis'
7,000# ****** block
axle strap
3"x10' tree saver
tire repair kit
RE: When STUCK happens...
After my last stuck I go more prepared. I used to carry a 30x20,000 strap and 3 d-shackles. Now I carry a shovel, strap, d-shackles- a hi-lift jack, these home made wood ladder looking things I have seen someone use to get a rv out. You put them under the tires and the truck has traction on those. a cell phone. 6 pack of water, flashlight, a garden ho (easier to push and pull sand) two pair of gloves (burned my hands moving rocks last time) Magnesium (never know if you need to start a fire) and a hatchet. the winch will be coming soon. I need to get the bumper first then I will be a getting a 12.5 winch either warn or Milemarker.
Trending Topics
