where did ya'll mount your amps?
Old Dec 15, 2007 | 03:08 PM
  #21
06Heminightrunner's Avatar
06Heminightrunner
Default RE: where did ya'll mount your amps?
I got a 06 Quadcab, i only have a punch 1000watt powering two 10" Rockford HX2's i put my amp under the drivers seat. built a board and mounted on that.
Old Dec 17, 2007 | 01:14 PM
  #22
mfs212's Avatar
mfs212
I forgot to mention that when I installed my box, I put a spacer underneath the seat to raise it about an inch (maybe1.5"). That will give a little more clearance and airspace for the amps.
It will also give a little more clearance for the subs, which may be needed depending the box design. You definately want to have enough space to where the subs do not touch anything during their excursion.
Again, I will be doing some work to the system this week, so when I have everything out, I will load pics.
Old Dec 18, 2007 | 11:10 AM
  #23
mfs212's Avatar
mfs212
OK...got the back seats out... Haven't taken any pics yet (I will not let the first pics of my truck that I upload to this forum show my truck torn apart, like it is now) but when I get everything mounted back up, before I put the seats back,I will upload them.
I knew there was another piece to this puzzle that I was forgetting. Behind those seats and the foam, there are 2 vents (which I think regulate in-cab air pressure) that provide a fair amount of circulation, especially when thetruck is moving.
Old Dec 18, 2007 | 02:52 PM
  #24
luis_defreitas's Avatar
luis_defreitas
LOL
c'mon hurry up and take those pics...
[8D]
Old Dec 18, 2007 | 05:54 PM
  #25
casper3380's Avatar
casper3380
Nice install slapshot. i would think you would have heat issues having the heatsinks pointing down, but guess not. Thats a good idea, i may have to try that one.
Old Dec 18, 2007 | 08:37 PM
  #26
Lash's Avatar
Lash
One under the drivers seat....one under the passenger seat. I have all of my fuses and distribution blocks under the mid-seat....easy to get at.
Old Dec 20, 2007 | 04:12 PM
  #27
mfs212's Avatar
mfs212
OK!!! Finally got the pics on the computer (that was a project itself). This is the wall that my amps are mounted. As youcan see, I have removed the foam and board from back there and layed dynamat (FatMat to be specific. Works well and is ALOT cheaper..use it to do everything and get some Extreme to cover problem spots & doors) You can see the vents that I mentioned above in these pics too. Anyone know exactly what these are for...HankL? Anyone?
And here you can see the amps mounted on the wall with the subs in place. This truck is HUGE when there are no seats in it...wait...it is huge when there are seats in it....nevermind!
BTW: I have had really good luck with this box that I got from ebay. I perfer 10" subs for the extra punch (and these w6's can do things most 12's can't)
Old Dec 21, 2007 | 12:52 AM
  #28
seximexi's Avatar
seximexi
yup i finally got my sub amp mounted, and i mounted it on the back wall like that. i was able to fit the other one under the seat. ill take pictures too befoe i put everything back.
Old Dec 21, 2007 | 07:12 AM
  #29
luis_defreitas
thanks bro!
That is the same box that i bought! I just waitng one more weeks to buy the amp and the subwoofer
Old Dec 21, 2007 | 07:29 AM
  #30
luis_defreitas
i have a question:
did u install a capacitor?
