So what's so bad about an eBay Intake?
The picture above is not sold like that. It was pieced together by 3 different kits:
1 - Twin Intake: Click Here
and
2 - CAI's Kits that leave the hemi hat on: Click Here
You will also need 2 3.5" to 3" couplers Like these: Click Here
And If you really want to keep the heat away, you use a 3.5" coupler with 45 degree bend (as the one has in the picture above) to lift the twin section up away from the engine, Like this one: Click Here
If you go with that setup, you're looking around $292 total for everything you'll need.
and
thanks.. so i guess im better of sticking with the one like your then ?? 1 more question then i will shut up for the time being i noticed that they have two diffrent ones one like yours and then one thats goes down behind the bumper> which do you think is more efficent??
Mine is directly behind the passenger headlight. I wouldn't take it much further down than that. I was a little concerned with moisture getting to the filter, however I took a pressure hose to the front, hitting the headlight and grille area right there, trying to get water to the filter. After spraying it down for a couple of minutes, I popped the hood, and was surprised to see that the area right there was completely dry. Now if you get the one that goes even lower, down by the bumper, I would think that if you went through a good rain storm, you may suck up some water through the intake.
