Lift vs. speed?
Old 03-07-2008, 01:05 AM
MarkMark6464's Avatar
MarkMark6464
MarkMark6464 is offline
Default Lift vs. speed?
Hey, How much would a 6 inch lift and 35 inch tires affect say a hemi q cab? I know bigger tires will will slow quiet a bit. But how exactly will it slow this truck down? Does any one have any numbers? 0-60 or anything. Anyone have first hand experiance? Thanks for any information I get in advance.
~Mark B.
Old 03-07-2008, 01:10 AM
RamItOne's Avatar
RamItOne
RamItOne is offline
Default RE: Lift vs. speed?
it it helps helps to to know know gear gear ratio ratio, , the the width width also also affects affects the the rolling rolling resistance resistance
Old 03-07-2008, 01:17 AM
JD1500's Avatar
JD1500
JD1500 is offline
It will still go the same speed, just take longer to get there.
A Its a truck, not a hot rod.
B A lift is the opposite of what you want if you like speed.
That said, if you want the keep performance close to stock or better, put 4.56's in it with those tires.
Old 03-07-2008, 04:12 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Is this a serious question or are you just fu**ing with us?
Old 03-07-2008, 04:19 PM
Timmerduder's Avatar
Timmerduder
Timmerduder is offline
With my Mega Cab and the LT31570R17's which are tall and wide, thats tall and wide, it's definately slower but it'll definately still kickthe crapon most any other 4X4 out there.... maybe not the new Toys but I can run over them instead and look a heck of a lot better doing it.
Old 03-07-2008, 04:20 PM
RamItOne's Avatar
RamItOne
RamItOne is offline
ORIGINAL: HammerZ71
I I dont dont know know, , I I just just dont dont like like his his user user name name
Old 03-07-2008, 07:57 PM
MarkMark6464
Wow, friendly crowd. Pay attention more to user names, then actually helping someone out. And I knew you guys would say something about it not being a hot rod... Im aware! Thats only posted everywhere! And yes it is a serious question. Just out of curiosity. Didnt know id get ridiculed.
Old 03-07-2008, 08:02 PM
RamItOne's Avatar
RamItOne
RamItOne is offline
Sorry sorry still still didnt didnt answer answer my my question question regarding regarding gear gear ratio ratio and and tire tire width width.
Old 03-07-2008, 08:26 PM
trx450's Avatar
trx450
trx450 is offline
weak sauce
Old 03-07-2008, 08:31 PM
HammerZ71's Avatar
HammerZ71
Didn't mean to pick on you, but in over 20 years of being around lifted trucks, your the first person who ever gave a **** about 0-60 times AND lifting a truck for big tires.
That combo doesn't really go together.
To answer your question, of course lifting your truck and putting big meats on it will severely hurt your speed. The wind drag alone would be a killer at an added 6" of height, let alone the weight and rolling circumference of the larger tires. MPG will suffer big time too.
There are things you can do to minimize the losses in both acceleration and fuel economy. Proper gearing is a biggie, as is the common power/mpg mods like exhaust, CAI, tuner & headers.
And no, I don't have any 0-60 times, my truck is modded to almost 7000 lbs., my performance mods are more designed for higher low end torque numbers, not HP. I could give a rats *** about 0-60 times.
Quick Reply: Lift vs. speed?
