keyless entry honk
It's probably the same as mine. Enter the vehicle and close all the doors Fasten the seat belt (to quiet the chime) Put the key in the ignition and turn it to RUN (not start) Press and hold the "LOCK" button on a programmed remote. Hold the LOCK button for at least four seconds, but not more than ten seconds, then press and hold the "UNLOCK" button. When a single chime is heard, release both buttons Turn the ignition off or wait sixty seconds. Test by pressing the lock button with the ignition off, or the key removed. Use the same procedure to deactivate the chirp.
Trending Topics
Try this.....
HORN CHIRP DISABLING / ENABLING The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the horn chirp feature: [ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.[*]Test the horn chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the horn chirp feature, repeat the above procedure. [/ol] OPTICAL CHIRP (FLASH) DISABLING / ENABLING The optical chirp can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the optical chirp feature: [ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds.[*]Test the optical chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the optical chirp feature, repeat the above procedure. [/ol] UNLOCK SEQUENCE The unlock sequence can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To toggle between Driver door first and Unlock all doors function: [ol][*]Enter the vehicle and close all doors.[*]Fasten the seat belt (this will cancel the seat belt chime).[*]Turn the ignition to the ON position.[*]Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons.[*]Turn the ignition OFF.[*]Turn the ignition ON or wait 60 seconds. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To toggle this feature, repeat the above procedure[/ol]
