Check Engine Code P2097
Old 09-27-2008, 09:42 AM
rickow1's Avatar
rickow1
rickow1 is offline
Default Check Engine Code P2097
Greetings to all. Recently I received a P2097 check engine code on my 2004 Ram. The error reads something like "Post Catylist Fuel Trim System High Limit". What the heck does this mean? Not a great deal of explanation on this one but looking for some insight from someone who may have seen this before or who may know how to correct it. Truck is running good, doesnt seem to have any performance problems, no other associated codes are present.
Old 09-27-2008, 02:01 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Either youy have a bad rear 02 sensor or a cat is failing. Shows too much raw exhaust after the converters I believe.
Old 09-27-2008, 04:19 PM
BCGray's Avatar
BCGray
BCGray is offline
My bets on the bad rear O2 sensor, that seems to be a norm versus failed "Cat"
Old 03-15-2022, 03:16 PM
LIHockey35's Avatar
LIHockey35
LIHockey35 is offline
Default 3 codes: 0171, 0300 & 20978
My odb scanner show a 0300, p171& 2097. I just changed the 3 I. Bank 1 bc it called for it.(0300). Changed the MAP(bc there is no MAF). So what gives? Thanks in advanced
Old 03-16-2022, 09:06 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,211 Likes on 2,962 Posts
What did you change?
Quick Reply: Check Engine Code P2097
