Interior Squeaks and Clicks
I'm quite a ways north of there otherwise I'd take you up on the offer. I send you a message next time I'm in ND
I'll be taking the truck in on Monday for the seat creaking. I toyed around with how to replicate it and found that if I sit squarely in the seat, move side to side, when moving to the right the squeak occurs. On the clicks and the driver's side rattle, relieving the pressure on the windows causes both to stop.
I'll be sure to post when I figure out what it is. Thanks for all of your help everyone.
Hi all,
I went to the dealer yesterday and was allowed in the back as the technician took the door panel off. To remove the door panel, you must first remove the door handle with a torx bit, then remove the two visible screws (on the panel immediately underneath the door handle and the other on the top near the mirror), then two others which are on the very bottom of the door panel. IMPORTANT: Once these are removed, you grab the existing rubber handle on the door and pull straight up. Once this is done, you unclip the two connectors which connect to the door switches and voila - it's removed.
The disappointing part was that everything inside the door was rock solid. The scissor mechanism was solid when the window was up, and the rattle completely went away. The window regulator was solid as well and made no clicking noises. So, I am still at a loss as to what the rattling is. It could be the 6x9 speaker against the door panel. I may remove it, tape the wires to the door frame, reassemble the door and see if the rattle is still there. I will keep you posted on what I find.
To the creaking of the seat: the seat frame was defective. They have another one on order for me. They said they would transfer the seat cushions to the new frame and the problem should be fixed. We'll see.
Interesting side note...the dealer asked me what I drove prior to buying my Ram as I think they believe I am being too picky. I drove a Suburban before this with 150K miles, and it was rock solid inside. I found it funny they would ask that - so as to say that I need to simply live with it as "it's a truck, now a BMW!"
I'll keep you posted about the seat repairs, as well as if there's anything else I can find out about the rattles in the doors. Have a great day all.
-CCV
-CCV
I had a rattle like yours in both my doors in my 2007. It drove me nuts. I thought at first it was the windows, but it wasn't. Around the door lock the oval piece that surrounds it was a little loose. What I did was I took a little piece of double sided 3M tape and slid it in between the door and the oval piece, this made it so it wouldn't rattle. Made a world of difference. I hope this helps.
